Question about Nokia 6270 Cellular Phone
RE:NOKIA 6270 SCREEN PROBLEMS
I have a Nokia 6270. The phone suddenly developed screen problems. First it started by showing rainbow-like horizontal lines across the screen.Sometimes,the lines disappear and the phone goes completely blank. Sometimes,the screen-saver appears for some seconds and the vanishes.It can still take calls but you wont be able to verify the caller from the screen. What may have caused this as the phone did not drop on any hard surface before this problem started. I await your prompt response. Thanks. Frank C. Obidegwu
  • 41 Answers
The software in your mobile has gone phut. It your mobile has a USB port the software can be changed ie reinstalled. You might have got viruses if you connect to the internet with it. If there is no USB socket, try to see if its covered by warranty. does that make sense
Posted on Mar 10, 2009
My nokia 6270 having problem that when i start the cell it shows nokia and after in screen it shows that contact service what i do.
Contact service means your mobile is locked with some network , so when you on the mobile it displays as contact service ,
so for this problem you have to unlock your mobile, if you unlock means after that you can use any network at any where in the world.......
Get the unlock code for your mobile through this site Unlocking4u.com , it has the best instructions and easy methods for getting the code for your mobile from the network lock......
Oct 20, 2011 | Nokia 6270 Cellular Phone
I have forgot my restore factory setting code(Nokia 6270). My IMEI no is 353259/01/221419/8.
just follow the steps
Switch-off your phone. Backup your mobile .
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
Hope this helps,
Jan 29, 2011 | Nokia 6270 Cellular Phone
I lost my Nokia 6270 mobile today on 15th April 2010.What should i do?I have its IMEI number.Please let me know as early as possible.
Switch-off your phone. 1. Press and hold 3
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
After a few
will
back to original system and factory settting.
Apr 15, 2010 | Nokia 6270 Cellular Phone
My nokia 6270 display is blinking when i start my phone & i can't see menu in screen because the diplay is bliking very roughly.plz. tell me what's problem in this?
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Aug 11, 2009 | Nokia 6270 Cellular Phone
2 or 3 horizontal lines in my nokia N95 8Gb display
90% chance LCD problem...eventually those lines fill up the screen. Soln: Change the LCD.
10% chance of moisture problem. Dry it out by-
1.take the battery off
2. put it in a bowl of uncooked rice.
3. make sure the phone is covered by it, and let it stay for 5-10 hours.
Rice should absorb the moisture and could solve the problem. If it doesn't soln:1 is the only way out.
Jul 22, 2009 | Nokia N95 Cellular Phone
Nokia 6270 Display Light
check your backlight settings
May 05, 2009 | Nokia 6270 Cellular Phone
How to format phone memory nokia6270
problems whit nokia?
here u can see: http://www.nokiausa.com/get-support-and-software/repair-and-recycle#
Jan 09, 2009 | Nokia 6270 Cellular Phone
Nokia 6270 some butons do not work
Yes its happen with nokia 6270 that after some time key pad do not work properly. so to solve this problem you should know how to open it.i too have the same and i opened it to work keypad normally.so if you want to open it take a knife and use any corner from top,just insert it and pull it up ,you will see it opening do the same for other corner ,when it is open use a cloth to clean the surface of the keypad .if you are unable to open it please take it to any mobile repairing shop..
for your second issue phone delaye when starting phone..
for this there are many reason ,
1st your mobile is filled with too many sms ,
2nd device memory is full.
3re memory card is of 1gb and it is full
so all this can make your mobile delay when starting .
Solution :
You can use settings > Restore factory setting .type security code and let it restart..
If still you see delay for few seconds
You can update your mobile firmware(software).
Just install nokia pc suite and than instal nokia software updater ,if you dont have nokia software updater you can download it from nokia website ..install nokia software updater .after that use your cable to connect mobile with computer .start nokia pc suite you will see a option "UPDATE PHONE SOFTWARE ".click on this and follow on screen instruction to update your mobile firmware with the latest firmware....this will definitely resolve the issue that you are facing and it your mobile will work faster than before as how my nokia 6270 working ................thanks
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you provide your feedback..
Thanks for using fixya support..You have a wonderful day
Jun 06, 2008 | Nokia 6270 Cellular Phone
No Network in my Nokia 6270
SHOW THESE PROBLEM TO SIM BRAND GALLERY THEY WILL HELP U
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Mar 27, 2008 | Nokia 6270 Cellular Phone
Nokia 6270 Cellular Phone Logo
161 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
