Question about Lexmark X5150 All-In-One InkJet Printer
It says cartridge error 50c
What do i do?
  • dgrimes84 Mar 09, 2009
    how do you do a realine function i have no guide
  • 99 Answers
Hi, Remove the cartrige from the printer and then clean them with a tissue paper as well as clean the cartridge holder too.......
Posted on Mar 09, 2009
  • 294 Answers
HAVE YOU PULLED OUT YOUR INK CARTRIDGE'S AND RE-INSTAL ALSO CHECK THERE INK LEVEL'S AND RUN A RE-ALINE FUNCTION
  • JEFFrey BAKER
    JEFFrey BAKER Mar 09, 2009
    OK AFTER YOU RE-INSTAL YOUR INK CARTRIDGE AND CLOSE THE COVER IT SHOULD RE-ALINE ITS SELF
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
Apr 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
Error 50c
The 50c error indicates that your cartridges or one of your cartridges has shorted. Please check which cartridge is causing the error. Remove both cartridges from the printer and close the cover. Unplug and replug the printer to the power source to reset it. When the printer turns on, insert one cartridge first and close the cover. If no error appears, insert the other cartridge. Replace whichever cartridge is causing the error. I hope this information has been helpful. Thanks.
Dec 12, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge error 50c
The Cartridge error 50c indicates that the printhead(s)/cartridge(s) has shorted. Follow troubleshooting steps available at http://bit.ly/8Zf7ef. If error continues even with brand new genuine Lexmark cartridges, contact Lexmark technical support for assistance. Thank you for choosing Lexmark.
Sep 20, 2010 | Lexmark X6170 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
Error 50c
Hi there Error 50c
Gave it a go it may work for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Dec 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
color cartridge.
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
color cartridge.
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
