Question about Sony Playstation 3 (PS3) Console
Won't turn on
When turning on green light beeps turns yellow then red and doesn't come on at all
Did you keep you PS3 in a enclosed environment? This question is only to help eliminate the possibility of the HDD failure. Does the fan run? My guess this may be a hardware failure.
Is your PS3 still under warranty? If not, you may want to try this. Get your hand on a Laptop HDD considering it is the same size as the PS3. Buy an adapter so you can hook up the HDD from the PS3 in your PC. Copy the HDD entirely onto the new drive. (This is only under the assumption the drive is failing but not dead). Reconnect the HDD into your PS3.
If it is the fan, go to your local computer store and buy a replacement. You may want to consider purchasing an external fan that snaps on the PS3. Good luck.
Posted on Mar 09, 2009
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
  • 85 Answers
SOURCE: Flashing red light and cannot eject game
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
Posted on May 18, 2009
SOURCE: From standby PS3 wont turn on.
that sounds like your main power supply unit
Posted on May 29, 2009
flacooo1
  • 172 Answers
SOURCE: PS3 Wont Turn On
Hi my name is Juan and I do fix and sell playstations3's so I do know your problem better than any body here the main problem you have is similar to the xbox360 red ring of dead so for now your ps3 is dead no way to turn it on but we have a fix for this problem the only bad part of this is that is done with a special system that is controlled by computer so not every one can do this like the xbox360 ps3 is more complicated in order to get your system up and running we need to have the motherboard or the completed ps3 to reflow the graphics chip some of the connections under the chip are not making good contact and this problem was cause by excessive heat so your ps3 needs to be open and the motherboard needs reflow and new thermal compound to dissipated the heat better there is some guys on ebay they do this type of job there I only sale parts and ps3's on ebay I don't offer this service on ebay but I do have the system to do it so if you like to see your system running again let me know I am located in Georgia.
Posted on Jun 10, 2009
  • 64 Answers
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
Posted on Aug 15, 2009
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
My ps3 turned off during game play and the light flashed blue green yellow and then kept flashing red and if I wait a long time and try again the fan turns on light god blue for one sec then turn a yellow...
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
May 03, 2012 | Sony Video Game Consoles & Games
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Ps3 80g light turns green flashes yellow, then
Unfortunatly your ps3 is dead, I am sorry for your loss.
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStationĀ® 3 (80GB) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
