Question about D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL)
How to configure the local ip address to Dlink make DES 1226R 24 Port Manged Switch using web interface, bcozit is already installed and working woth LAN & not possible to disconnect from the LAN.
  • 17 Answers
SOURCE: DLINK SWITCH DES-1008D
It sound like your network is setup as follows;
Modem -> Switch -> pc's
Most ISP's will only lease you a single IP your network should look more like this;
Modem -> routing device -> pc's
Where routing device is an actual router or firewall that leases private addresses to your pc's and routes outbound traffic to the public address your ISP has leased you.
Do you have more than one computer plugged into this switch? Do none of them work?
Posted on May 02, 2008
chudd1
  • 18 Answers
SOURCE: what is the default ip address of dlink 8port switch.
should be 192.168.01.0
Posted on May 01, 2009
  • 9 Answers
SOURCE: static routing between two routers
You need to go to router B and configure a route to the 192.168.1.0 network with a mask of 255.255.255.0 and a gateway of 192.168.0.1.
Cheers!
SOURCE: i want to configure d-link des-3026 switch through the web-browse
how to configure dlink switch
Posted on Aug 10, 2009
kurtis_1318
  • 382 Answers
SOURCE: what is the default IP
This issue is more on a hardware. 169.254.XXX.XXX refers to an INVALID IP ADDRESS. Here's what you can try:
>release the ip address by running command prompt:
>>>>Click START>type CMD on the search bar>type IPCONFIG /RELEASE and hit ENTER
>>>>ip address will be set to 0.0.0.0
>renew the ip address: by typing IPCONFIG /RENEW and hit ENTER
>>>>it will generate new sets of ip addresses
However, if it still gives you 169.254.XXX.XXX you need to flush the DNS by typing IPCONFIG /FLUSHDNS and hit ENTER and it will immediately tell you that the DNS had been successfully flushed.
>Check your ip address by typing IPCONFIG and hit ENTER
That's the best I could do for the issue that you have.Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Posted on Feb 03, 2011
D-Link DES-1008D 8-Port drivers
Drivers are not required, the device is a networking device and doesn't interact with the OS directly anyway.
What you might be looking for is the Web Interface that allows you to change settings, update firmware etc.
By default most are configured to either 19.168.0.1 / 10.0.0.1 / 10.1.1.1
Open your web browser, type one of those into the web address bar until you find the one that brings up the web page, from here you should be able to configure a few things.
If you are unsure click start > run > type: cmd > hit enter> a dos prompt appears, now type: tracert www.google.com
You will see IP addresses appear as the computer traces the path the packets are taking to reach google, what you are interested in is the first address that is in that list, that should be your switch ip address and all you have to do now, is type that address in your browser address bar. This should now bring up the configuration page for the switch.
Still unsure of the address, head to D-links website and find the support link and search for your model of switch, from here you can bring up the detailed users guide which will contain instructions on how to access the Web interface also.
Apr 15, 2013 | D-Link DES-1008D 8-Port Ethernet Switch...
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
I have dlink switch model DES-1024D i need default IP address
The default IP address for most D-Link switches is 10.90.90.90
Jun 13, 2011 | D-Link DES-1024D Express EtherNetwork...
I want the default ip address, domain name and password of "dlink des 1024d switch"
Hi,You can get your expected domain name also getting hosting at just $1.99 per year from this http://www.tucktail.com/ site ,visit here for more details.All the best.
May 11, 2010 | D-Link DES-1024D Express EtherNetwork...
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
other units cant connect to my installed port hub and were having hight mare connecting it
Apr 09, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link Express EtherNetwork DSS-5+ (NTSWDLDSS5PL) Logo
145 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
