Question about Panasonic AG-DV2700 Mini DV VCR
F11 error message in ag dv2700 during play.
Again u put dvr off and then on it starts normaly.and after certain time same error appears.please help
    Problem Solver:
  • 4 Answers
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Posted on Aug 07, 2011
When i insert a tape into Panasonic AG-DV2700 Mini dv Playerecorder. It closes normally and then it puts the tape back out staight away Thanks Maurice
Dear FixYa customer,
There can be several reasons for the tape spitting back out including, a defective tape, foreign object/lablel in the cassette compartment, unit in timer recording with tab knocked out on tape and then actual mechanical and electrical faults.
I will concentrate on the mechanical and electrical faults here, since you can verify the others.
Electrical, would include the Power supply, and Micro processor circuits.
A weakened power supply due to deterioration of the filter components will kick the tape out if the power supply voltage drops below a certain value. The filter components deteriorate with age and heat, and then put out less voltage.
There are critical timing circuits, and sensors that control the mechanism positioning and send signals to the Micro processor. The tape in sensor, mode switch, and LED are common faults here.
Mechanical faults include the Cassette Loading Assembly, Capstan, and Drum motor. A fault in the casseette housing assembly that won't allow it to load 100%, a Drum or Capstan motor that is sluggish or frozen will send a signal to he CPU to kick the tape back out.
The Power Supply is a common failure.
An experienced technician can verify the power supply voltages and replace the filter components for approximately $25.00 plus labor.
Thank you for using FixYa
May 13, 2010 | Panasonic AG-DV2700 Mini DV VCR
Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Mar 03, 2009 | Nintendo Video Game Consoles & Games
I cannot get on the internet. It gives me an error message- Network too busy. please try again. This is my cell phone. The Samsung m300
Certain times of day, cell phone traffic is at its busiest. This error message occurs during these times when the network is unable accept more traffic. Try again in little while and it should work. :)
Nov 23, 2008 | Cell Phones
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: waveform@wwdb.org
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Jul 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Help Please!
You have signalling errors that come from, more than likely, a bad ribbon cable linking the mechanism to the CPU. Good luck on this as it is a service headache.
Apr 23, 2008 | Panasonic AG-DV2000 Mini DV VCR
F08 Error message, keeps shutting down
Get it to a shop. The error is a drum servo related problem. Don't force the mechanism or you'll be out even more...accordianman
Feb 15, 2008 | Panasonic AG-DV2700 Mini DV VCR
Panasonic AG-DV2700 Mini DV VCR Logo
335 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
