Permutaion in how many ways can 6 people stand in a row?
  • 294 Answers
36
Posted on Mar 09, 2009
Some one please tell me how to get the plugs right on 2001 mercury moutaineer on the coil
The firing order is 1-4-2-5-3-6. But on the coil they should be in this order: 1-2-3 on back row, and 5-6-4 on front row. Standing from in front of car facing engine compartment, going from passengers side to drivers side. Hope that makes sense.
Kip. Martin, service manager at a Ford dealership.
Jan 30, 2015 | Mercury Cars & Trucks
Whywontgoogleacceptanyusername
It's a big world. There are many people trying to use the same name or similar. I couldn't get the one I wanted (many times).
So lets say you want petersmith....no way ! so many petersmiths.
So you have to get creative, use some numbers...instead of "i" use "1" so that would be petersm1th and so on..... there will be a permutaion somewhere. If you have a very common name like me then it just takes a little more time.
Jan 08, 2015 | Cars & Trucks
How to remove third row seats in 2001 Mitsubishi Chariot
same way as you slight the front seat forwart.lift the bar up underneed the seats
May 30, 2013 | 1998 Mercury Villager
Need plug wiring diagram for 2001 ford widsrtar
The rear cylinders are from passenger to drivers side 1-2-3 The front cylinders are 4-5-6 The coil as you standing in front of the vehicle will be Back row from passenger to driver side 4-6-5 Front row 3-2-1 Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Oct 23, 2011 | 2001 Ford Windstar
Game 100 professor layton and the curious village please solve
Most of the squares you make will be tilted 45 degrees to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares at a diagonal. Hint 02 You want more specifics? All right, here's the location of one of the squares. Connect the four pins in the top-left corner to form a tiny square.
Just so you know, this is the only square on the board that isn't tilted. Hint 03 The largest square contains the pin that's third from the top on the left column and the bottom pin from the far-right column.
You also need to form a small diagonal block using the two pins lined up diagonally on the bottom-left portion of the board. There are two more small squares just like this one on the board. Solution For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
May 31, 2011 | Nintendo Professor Layton & the Curious...
I cannot remove the stand for my evotel elcd32usb, can you help me please
There are 6 screws in the centre back of the TV, 2 rows of three. There are arrows embossed on the plastic case to identify them.
Remove all 6, then pull the stand off.
Apr 26, 2010 | Televison & Video
Help with Curious Village game on Nintendo DS
Hi Gill
Hope this helps and good luck!
Scott
Mar 25, 2010 | Nintendo DS Console
I can get 7 squares but I'm told it's wrong
SQUARE 1.= use pins 1 and 2 from row 1 and pins 1 and 2 from row 2!
SQUARE 2= use pins1 from row 4 , pins 1 and 3 from row 5 and pin1 from row 6
SQUARE 3= use pin 3 from row 3 , pins 2 and 4 from row 4 and pin 4 from row 5
SQUARE 4= use pin 5 from row 1 , pins 4 and 6 from row 2 and pin 4 in row 5
SQUARE 5= use pin 3 from row 1 , pin 5 in row 2 , pin 2 in row 3 and pin 3 in row 4
SQUARE 6= use pin3 in row 2 , pin 5 in row 3 , pin 2 in row 5 and pin 3 in row 6
SQUARE 7= use pin 4 in row 1 ,pin 1 in row 3 , pin 5 in row 4 and pin 2 in row 6.
Feb 24, 2009 | Nintendo Professor Layton & the Curious...
Removing the 2nd and 3rd row seats
3rd row, you simply pull the lever which makes the back fold down and then grip the handle located on the bottom and pull toward you slightly hard. They are heavy so it seems like they aren't coming out, just pull hard. second row, you flip all the way up and push with them standing up and they come unhooked. Good Luck! I didn't have any problems, except they are at least 50+lbs!
Nov 18, 2008 | 2007 GMC Yukon
Ignition timing
It is not necessary to set the timing on a computer controlled engine. I think you mean to ask where the wires go. First, the motor is numbered down the left bank (that is standing in front of the car looking at the motor) 1 - 2 - 3, and the right bank is numbered 4 - 5 - 6. The coil pack is setting sideways and it numbers (left to right) 5 - 6 - 4 (front row) 1 - 2 - 3 (back row).
Aug 09, 2008 | 1998 Ford Explorer
Computers & Internet Logo
David Payne
David Payne
