Question about Panasonic DMR-EH50 DVD Recorder
My dmr-eh50 recorder will not read blank disc.
    Sniper:
  • 55 Answers
Most others have suggested a possible hardware issue. It could also be that your burning software is not working well. Try downloading Nero 6 from ftp://ftp6.usw.nero.com/software/Nero6/Nero-6.6.1.15a.exe . Small file and quick to install. Windows XP does not by default handle blank disks easily unless you have a good burning application installed. Use this and let me know if you are able to burn some files onto the disc.
Hope this helps. Pls let me know if you need further info on this.
Thanks,
VJ
Posted on Mar 09, 2009
  • 154 Answers
Clean the tray using a disk cleaner disk. and try again
  • Panasonic Master
  • 13,433 Answers
Only blank discs? please try a lens cleaner , a dvd lens cleaner and also try blowing some canned air inside, possibly dirtly lens. Or then the optics may be failing. But I suspect its more likely dirty lens if that doesn't solve the problem repair or replacement of lens maybe required.
Panasonic DMR EH50. Picture is dominated by the colour pink. TV not affected.
Please check your Blue and Red component cables on both the recorder and your TV. One is probably loose.
Apr 07, 2014 | Panasonic DMR-EH50 DVD Recorder
I have a panasonic dmr-eh50 dvd recorder. The last time I tried to play a disc a few days ago the disc came out split down the middle. Since then it has not been able to read any disc i put in
I expect the damaged disk spun round and has damaged the lens assemby and laser.
If the unit is not too old, Panasonic are very good, price wize, for repairs.
Hope that helps.
Dec 29, 2010 | Televison & Video
Pan DVD Recorder DMR-EH50
Press enter and 2 at the same time for more than 3secs
Oct 29, 2009 | Panasonic DMR-EH50 DVD Recorder
Has really slowed down dubbing - and disc is heated when removed, after only one dubbing and finalizing.
The speed of dubbing depends on the max writing speed of the disc used.
A disc always gets warm after using,the laser gets verry hot.
Jul 31, 2009 | Panasonic DMR-EH50 DVD Recorder
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
Check your user guide for the answer.
Nov 08, 2008 | Panasonic DMR-EH50 DVD Recorder
Does the DMR EH50 work with satelite tv
Yes Connect using Scart
Sat to EH50, Sat to TV as per page 15 of the manual and it should work fine mine does
Dec 05, 2007 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-EH50 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
