Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Network sharing i have a WA3002G4 ADSL2+ modem with a bsnl dataone connection.The modem got 4 lan ports but only one user is only able to connect to the internet.How to do it if all the 4 want to get connected to internet at the same time
Go into the TCP/IP protocol properties where we have option to obtain IP address automatically. have only one system with IP address and the remaining 3 systems select obtain IP address automatically. It will work.
Posted on Mar 25, 2009
How to cofigure my Dlink 502T modem for BSNL connection at chennai
If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . . Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29 Subnet Mask As 255.255.255.0 Default Gateway As 192.168.1.1 Preferred DNS 208.67.222.222 Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem Make sure the Power LED, Link LED and USB/LAN LED are on/blinking Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/ Input as follows USERNAME : admin PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows Name : BSNL
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0 Encapsulation : LLC Select LAN : LAN GROUP 1 PVC : new VPI : 0 VCI : 35 Leave all others at default values Then click apply The go to TOOLS tab Click “system command” (left hand side) Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows Now goto Control Panel->Network Connections Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
Feb 11, 2010 | D-Link Computers & Internet
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
My dataone WA3002G4 (BSNL) WiFi router keeps resetting
Try to upgrade the firmware of the router.
Apr 21, 2009 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
Laptop not connected to wireless network
You may have to log into the router with a computer that is connected by cat5 cable using the ip address of the router, eg 192.168.15.1
make sure the radio is broadcasting.
on the wireless activity select your wireless from the detected
units, this will allow your wireless to function as the wireless will assign it an address.
Mar 31, 2008 | Computers & Internet
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
239 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
