Question about Microsoft Xbox 360 Elite Console
Xbox 360 Console, Faulty, NO DISPLAY!!?? - Microsoft Xbox 360 Elite Console
    Problem Solver:
  • 16 Answers
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Posted on Mar 10, 2009
  • 12 Answers
SOURCE: to play this disc you must put it in a xbox 360 console message
Shut it off, turn it back on, clean the disc.
Posted on Jan 01, 2008
SOURCE: 360 drive only reads dvds, not xbox 360 games, just says put in an xbox 360 console.
how do i flash drive
Posted on Mar 02, 2008
  • 3 Answers
SOURCE: xbox 360 insert disc problem
xbox repair in mumbai :- 9819767710/9867635653 ?
Posted on Jan 23, 2009
  • 6 Answers
SOURCE: How to connect a hive console cooler to xbox 360 console?
You Have a cooler that is incompatible with your system.
the HDMI is for the Newer Xboxes
Posted on Feb 12, 2009
  • 30 Answers
SOURCE: to play disc put it in an xbox 360 console.
when this happens, it either symbolizes that somehow, your tsop32 chip has corrupted in your dvd drive and has lost the dvd key, or you (someone) has attempted to flash the firmware on the dvd drive and it has ended in a failure and destroyed the initial firmware. basicly, if you have your dvd key, you can try to reflash the drive with working firmware (tutorials can be found everywhere) or, if you have warrenty left, send it in. if all else fails, find a person who knows how to disassemble an xbox 360 + dvd drive, desolder the tsop32 chip, and rip the firmware. this can be costly though, and you'll need a new dvd drive afterwords if your old one gets broken in the process. and if you can't get the dvd key, well, your 360 is now an expensive dvd player.
best of luck
-Gadorach
Posted on Jul 13, 2009
How do u reset your xbox format to pop up on your tv?
If you're using the XBox 360 component/compositve AV cable, try the switch at the base of the cable to switch from HD to SD or vise versa. If that doesn't work, try MS's official reset instructions:
To reset your display settings, follow these steps:
  1. Make sure there's no disc in the disc tray.
  4. Note If you're using an Xbox 360 Wireless Controller, make sure only one wireless controller is connected to the console, and then turn off and restart the console by using the Guide button on that controller.
  5. As the console starts, press and hold Y while pulling the right trigger on the controller. The display settings are reset to the default settings, and then the console automatically restarts.
    Xbox 360 E or Xbox 360 S console: To reset display setting on these console models, you can also just turn off the console and then hold the power button on the front of the console down for about 10 seconds. (The lights will flash several times.)
Oct 20, 2014 | Microsoft Xbox 360 Console
My xbox 360 wont read anything
Either the disc reading laser is faulty or the disc drive itself is faulty and will need repairing possibly replacing.
Oct 18, 2012 | Microsoft Xbox 360 S - Game console - 4 GB...
Cant get onto my family settings my daughter changed the passcode and now she cant remember
you might have to erase the settings
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller. You can recognize the player one controller because the upper-left quadrant of the Guide button is lit up on that controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
    The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
Sep 22, 2011 | Microsoft Xbox 360 Console
How to reset xbox360 dashboard
  1. Turn off the console.
  2. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
  3. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
My xbox turns but the image docent pop out
  5. The console will restart and you will see the Xbox 360 logo again.
May 21, 2011 | Microsoft Xbox 360 Console
No video have sound when using component connection on my xbox 360 hdmi ok. help
Your resolution settings on the xbox are too high for your currently used cables or tv. To reset your console's resolution follow these steps: To reset Xbox 360 console display settings
  3. Turn on the console by using your controller (its best to have the controller plugged into the console rather than just using the wireless). To do this, press and hold the controller's Xbox Guide button until your console turns on.
Mar 12, 2011 | Microsoft Xbox 360 Console
Xbox 360 dashboard wont come up on tv
This is the no display error and you will need to get this fixed it is caused by a faulty or overheating GPU.
You can send it in to get this fixed or you can use a good Xbox 360 Repair guide to get this fixed fast!
I hope this has helped and if so can you please rate so it can help others.
Feb 22, 2011 | Microsoft Xbox 360 Console
Problems with XBOX360 (1.5 years old) Hear sound but get no picture. What could be wrong?
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  2. Turn the console off.
  3. Turn the console on. Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated.
  5. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console.
Jun 28, 2010 | Microsoft Xbox 360 Console
I put in 360 game into 360 console, message pops up to insert game into a xbox 360 console...that is what I'm putting it in!!!!
try putting a DVD movie, or A music CD in.
this will eliminate a faulty DVD Drive, or laser fault.
Mike @ compurepair.
Jun 19, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
941 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
