Question about Canon PIXMA iP1500 InkJet Photo Printer
My cannon pizma ip500 not printing anything please help, Donna
Priner is plug in port and wall and not printing!!!
  • Anonymous Apr 21, 2009
    I have the same problem and have been searching through web sites for a solution. With another canon numerous people suggested taking out the ink cartridges and pouring alcohol into the machines ink reservoir (with machine OFF) and letting it sit overnight. I am going to try it...nothing to lose, all Canon suggested fixes did not work.
Operator error
Posted on May 22, 2009
How to install samsung printer *** 4016 in xp
If your printer is a (USB) model, Windows should automatically detect and install it when you plug it in.
If it's an older model that connects using the serial or parallel port, you might have to install it manually from control panel.....add priners and other devises..............
Oct 12, 2010 | Samsung Office Equipment & Supplies
Cannot print
first do a power drain .. ie; unplug the power and usb and the power cord from the printer , then restart the computer..
After the computer restarts , replug the printer .. now check if it is printing..
Please check the priner icon as well .. check if it is Online or having any error .. (this is to be checked in the computer) .
if the printer icon is fine and shows ready .. then right click on the printer icon and go to properties .. now, click on Ports and see if it is assigned to the correct port..
Now, if that is also correct, then do a Level 2 uninstall, restart the computer and then reinstall the printer.
Aug 14, 2010 | Samsung ML-2240 Laser Printer
HOW TO INSTALL CANON MF 4100 PRINER DRIVER
hi
just follow the step
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · step 1 Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
· Step 2 Turn the computer on and wait for it to boot up.
· Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
· Step 4 Turn the printer on.
· Step 5 Click on "Start menu" and go to the "Control panel".
· Step 6 Find "Printers and hardware clip_image001.gif" box and click on it.
· Step 7 Take mouse and click "Add printer".
· Step 8 When you see "Welcome to the add printer wizard," hit "Next."
· Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
· Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
· Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
· Step 12 Pick manufacturer and printer. Click "Next."
· Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
· Step 14 Print a test page to be sure printer is set up and online. Click "Next."
· Step 15 Receive a successful completion of installation of printer message. Click "Finish."
Aug 05, 2010 | Computers & Internet
I have gestetner 645 i installed in windows xp machine with network.now inside the computer priner is on ready condition and i am able to ping printer. but when i print some document so its not display any...
check you have the correct port set up in the printer properties.. the default is usually parrallel or usb if connected with network cable open the printers faxes page on your computer and right click on your printer open the ports tab and check if it is set to TCIP you will have to enter the ip address here. you can get this by going to the copier press the 123 button at top left then press for printer and print the config page..hope this helps A
May 29, 2010 | Gestetner DSm645 Digital Imaging System
Document failed to print what we do?
1.check paper size setting on printing prefe. 2.check n reinstall priner driver and vertual com port 3.chek and relace USB cable
May 06, 2010 | Toshiba e-Studio163 Copier
I have a new network printer (Samsung SCX-5635FN) I cant get connection to the printer. I have connected to the LAN port of my router and tried both DHCP and static IP. I have try to change the LAN cable...
have yo installed the printer on to the system ( add a printer ), have you installed the correct driver for the printer
it is not a matter of just connecting leads and expecting it to work
Apr 11, 2017 | OKI C5300n Led Printer
Can't print
hi,
WPA keys is security key for ur network and when u run the wireless setuo wizard, use the key pad on the printer to punch in the WPA or WEP key.......
or
if u were using ur printer before wirelessly, then u should still have the ip address stored on   ur printer,
1) print network configuration by setup menu of the printer (setup>>network>>veiw network settings>>print network configuration page)
2)it will print out, in that u will have ip address.
3) go to priner and faxes, right click on the printer icon and go to properties and under ports tab, click on configure port and change the ip addres for the ip address wat u have if that doesnt work, click on add a port and select standard tcp ip port and new port at the bottom of the window and entry the ip address and proceed with that,,,,,,,,,,,it should resolve ur issue....
Regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
All flash lihgts are flashing and priner dont work
Hi
have you tried turning it off and unplugging it for a few minutes? pls keep us posted.
Thanks
Nov 14, 2008 | Epson Stylus Color 3000 InkJet Printer
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
Cannot connect
have your tried removing the driver and reinstalling? sounds like a corruption to me.
been struck by lightening / power surge?
anything funky in the computer's behaviour three days ago, but not related to priner?
Mar 24, 2008 | Epson Aculaser C1100 Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
202 people viewed this question
old marine
old marine
