Question about LG DLE2514 Electric Dryer
LG Tromm door reversal
HI, I have the DLE2516W, the door opens opposite to the washer and because I have them stacked in a closet its difficult to open the dryer door. Is it possible to reverse the door, it looks it but I'd like some confirmation before I try.
Thanks in advance.
  • thekreed Mar 09, 2009
    Ahh, that could be a problem then, there must be something because there's a door light, any advice?
  • 294 Answers
IF YOU SWITCH THE DOOR YOU MIGHT WANT TO MAKE SURE THERES NO SWITCH OR ANYTHING THAT THE DRYER READS TO SAY THAT THE DOOR IS SHUT OR OPEN IF NOTHING THEN IT SHOULD BE A PRETTY EASY SWITCH
Posted on Mar 09, 2009
  • JEFFrey BAKER
    JEFFrey BAKER Mar 10, 2009
    IF THE DOOR LIGHT IT TRIGGERD BY A TOGGLE SWITCH OR SOME SORT OF SWITCH THEN YOU COULD MOUNT THE SWITCH ON THE OTHER SIDE JUST AS YOU DID ON YOUR DOOR BUT IT'LL BE MORE WORK AND MAKE SURE THE CORD OR WIRE TO IT WILL REACH THE NEW LOCATION AND IS CLEAR WHEN THE DOOR IS CLOSED
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Hi, I can't open the washer's door when it's done washing. I tried washing again, turn on/off the main switch but the door just won't open up. Please help! The LG Tromm model is...
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Aug 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I looked for door switch kit and some descriptions say for stacking...i don't need that and have duet model 9200 in white. want both doors to open in opposite diections. do i need to buy kits?
ummm.. you can only reverse the door opening in oyour dryer, your washer CANNOT be switched it only opens to the left. the dryer can be switched and the "hine kit" if applicable, only contains a new peicw of trim to cover the exposed trim after revesing the door( the catches are on top and bottom no need to reverse them)
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2514 Electric Dryer Logo
901 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
