Question about Electronic Arts Harry Potter and the Order of the Phoenix for PSP
VIDEO PROBLEM Hello I have vid. res. of 1024x768 at 60 fps and this game says over range when run. and monitors shuts down. MY MONITOR size is 15" and I think my monitor size is no big, so its happening. TELL ME how to solve it and if any avail. patch. THANXXX
  • hackerboymay Mar 09, 2009
    but I can't change the res of my monitor to higher one because this is the problem!!!
    The Game tries to change it when running, but my monitor doesn't support it!!!
  • 294 Answers
HAVE YOU TRYED CHANGING YOUR RES ?FOR A MONITOR THAT SMALL YOU MIGHT WANT TO CHANGE TO A HIGHER RES AND NO PATCH OTHER THEN CHANGING THE MONITOR
Posted on Mar 09, 2009
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
Monitor will not start up
possible causes
1) video card slipped out of the slot, after shut the system down try reseat the video card
2) video card faulty
3) video card cable faulty.
try with some other vid cable, if it doesnt work with above mentined 1 and 3, then card cud be faulty.
Apr 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
I am using the Radeon 9200. I have "need For Speed 3". When I try to play the game, I hear the monitor click and tried to go to the game but then all of a sudden it kicks me out. Is this the video cards...
What kind of monitor are you using? With this card, DVI-I monitors will be limited to 1600x1200 resolution. The resolution coming from your card is too much for the monitor to handle. Try setting it to a lower res to get the game to work.
Cheers
Dec 29, 2009 | ATI RADEON 9200 Graphic Card
Some games need 1440x900 resolution to play but when i go to the display settings to change it, its not there just 1360x768, 1600x1200 and lower ones. I need help????
Hi there. If you're able to get 1600x1200 on the monitor, that should suffice--anything equaling or larger than the game's required res is ok...the picture will have a little bit of border on the edges because of the higher resolution but shouldn't be a hinderance at all. Remember this...the higher the resolution, the harder the graphics card has to work to maintain proper movement of the images in the game. Use the exact res if possible. However a close, higher res is fine, too.---Rick
Oct 03, 2009 | HP Compaq WF1907 Monitor
P191w lags when playing videos on full screen
the video card is too low on speed and memory. The lower end cards slow down the pc performance on videos and games.
Try to get a gig memory vid card at least
Jul 20, 2009 | Acer P191WBD LCD Monitor
Out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Jan 24, 2009 | ASUS VW193T Monitor
LCD and Gaming
Monitor should not have anything to do with frame rate.
If you have increased the resolution of your video card because the 19" is larger than what you had before, that could cause a frame rate issue.
Something else got installed, that is slowing down your machine...
Coincidence...
Connect the old monitor and what is the outcome? Does the frame rate improve again?
May 15, 2008 | Acer AL1916W 19" LCD Monitor
Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Jan 31, 2007 | HP T5300 (dc643a#abu) Network Terminal
Electronic Arts Harry Potter and the Order of the Phoenix for PSP Logo
83 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
akigawa
Level 1 Expert
Tre Elkins
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
