Question about LG KF310 Cellular Phone
THERE ARE WHAT LOOKS LIKE TWO PIECES OF PAPER SHOWING ON THE SCREEN AND I DO NOT KNOW HOW TO GET RID OF THEM
Im nott 100% but i think this is the symbol to show that the gprs has reception. I cant be sure as my manual is in spanish, but on all my old phones their is always a symbol on the screen to confirm the gprs is working.
Posted on Mar 15, 2009
Add showing jam paper while start copier
Hello Dear,
This means that paper is stuck inside the roller.
  • Please switch off the copier, open the panel where paper goes inside and try to remove the paper manually.
  • Make sure no paper pieces are left inside.
  • Once done, start it again and load paper slowly so that it does not get stuck.
Happy Printing!
May 15, 2016 | Office Equipment & Supplies
Paper jam in fuser how to solve my problum
remove the fuser unit a check for small pieces of paper inside , use a small pliers to remove the papers. if not disassembly the fuser unit and get rid of any papers inside.
Apr 25, 2016 | Office Equipment & Supplies
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
LOADED PAPER I ...GOES CROOKED
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Apr 04, 2012 | Office Equipment & Supplies
PHASER 3100MFP SAYS PAPER JAM BUT NO PAPER IN MACHINE
Hi there, if you have experienced a paper jam prior to this error, then try to inspect the rollers as there might be tiny pieces of paper shreds that might be stuck there. Or blow a canner air or a blower inside the printer to get rid of any obstructions.
Hope this helps. Thank you for using FixYa.
Dec 16, 2010 | Xerox Office Equipment & Supplies
No booklet came with my lexmark 2600 series
For color copies, you press the function key with two pieces of paper and color dots on it. For black and white copies, you press the function key with two pieces of paper and black dots on it. The link below is to the user's guide for your printer. Page 17 shows a diagram of the function keys, also, page 39 provides steps for making copies.
Lexmark 2600 Series User's Guide
Jun 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Thick marks on photo paper
You don't say whether the mark is a dent/dinge in the paper or whether it is a dirty or inky mark. If it is one of the rollers pressing and making a dinge in the paper you need to check for flat spots on the rollers. Do check all the rollers as the problem may be caused by another roller not gripping properly or the feed rolls being twisted therefore the one where the dinge occurs is over compensating. You can get rid of small flat spots or shiny bits on the roller by GENTLY roughening the roller feed wheels with a fine emery board. This will also clean off any dirty marks on the roller. You can clean dirty marks off the rollers with a non-lint cloth/specialist wipe. (I use baby wipes). Make sure you get rid of all the dust, as this will cause more marks. Clean the platten glass, again with a glass wipe or windowlene to get rid of any marks there. It is also worth taking out the catridges and wiping the ink surfaces. I use kitchen roll and the a baby wipe. Do test the baby wipe first to make sure that it does not damage the printer. If it is possible without taking the printer to pieces wipe the cartridge feed bars. I use a oil based specialist wipe fro this. Another thing that could cause the symptom that you describe is a piece of debris/stuck paper in the feed path. So check that the path is completely clear. You would be amazed at the impact of even a tiny scrap of paper stuck can have.
If you printer has a clean cartridge utility, do that for both cartidges and run the alignment routine before using the printer again. Print a test page to check that you have got rid of all the marks.
Good Luck Please send me feedback so that I know that this fixed the problem.
Carrie
Aug 31, 2008 | Lexmark X7170 All-In-One InkJet Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
LG KF310 Cellular Phone Logo
90 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
