Very strong smell from air conditioner
I have a terrible sickly smell in the apartment, worse when the a/c is on (both for heating and cooling). It is a very strange but very distinctive smell. This has gone on for several months. We have checked all the other possible problems including plumbing but have drawn a blank.
  • 400 Answers
You need to buy some airconditioning coil cleaner, which is a mild acid based solution and will not harm the aluminium fliliament or tubing in the evaporator. This should be done as a standard procedure at least once a year to sanitize the coil and remove bacteria and other baddies. Any normal cleaning liquid does not work. The coil cleaner penetrates the fins and makes a foam which pushes the dirt out of the coil. You will need to buy a small spray bottle and once you have done the cleaning part you can refil the bottle with clean water and spray the coil again. I am sure this will solve the smells.
Posted on Mar 09, 2009
Every time we try to use our gas fireplace the smell of gas is terrible. Why?
Turn it off at once do not use and phone the a gas company to come out and look at this asap
Jan 17, 2018 | Heating & Cooling
Ammonia smell
bad cooling unit Freon leaking cannot fix replace cooling unit or whole unit
Sep 25, 2009 | Dometic Rooftop RV Air Conditioner
Brunt smell and sweating
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Jun 04, 2009 | Goodman CKL24AR24 Air Conditioner
1997 Ford Escort Runs Poorly, Smells like fuel, now won't start.
it could also be your map sensor .it on the fire wall .or on the air in take.your motor is running rich that why it smell like gas .
Mar 28, 2009 | 1997 Ford Escort
Smell from Mitsubishi air conditioner
THE SMELL MIGHT BE FROM MOLD DUE TO HUMIDITY COLLECTING INSIDE THE UNIT NORMALY THE GAS A A/C USES IS ODERLESS OR MIGHT BE FROM STAGNET WATER INSIDE THE UNIT.
Mar 09, 2009 | Heating & Cooling
HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME A FEW DAYS AGO A UNKNOWN SMELL COMES THRU ALL VENTS IN AIR CONDITIONER MODE ONLY. WHEN HEAT IS ON THERE IS NO SMELL UNTIL...
This is a condition called Dirty Socks Syndrome air cleaners and dehumidify usually fix the problem also adding a uv light to the duct can remedy the problem the light is probally the cheapest solution
Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
Mar 23, 2008 | Kenmore 85250 Air Purifier
Heating & Cooling Logo
329 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
