FixYa.com
Tags:
Gateway SOLO 200ARC  Keyboard
200arc xp pro install problem
By Janice - usenet poster
I'm doing a hard drive replacement on a 200ARC laptop. I don't have
the original restore/recovery CD. I tried installing windows XP pro
using the key on the sticker on the bottom of the laptop. I get an
invalid key message.
I understand that Gateway uses OEM versions of windows. I am using an
original full version of XP Pro.
Is it possible that the version makes the key not compatible?
If so does anyone know where I can pick up a recovery CD? Gateway
doesn't provide them. They told me to do a Full (Destructive) System
Restore but I didn't have any luck with that either.
Any suggestions would be appreciated.
Thanks in advance
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Hart
Hart - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I was hoping I didn't have to go this route. It's my understanding
they can be a pain in the ass when trying to obtain a new Key
considering I'm just the repair guy and not the acutal owner.
>JR the postman
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
I installed my copy of xp pro with my key and that worked (that is not
staying on the puter)..
Using my copy of xp pro and the key that is on the sticker at the
bottom of his laptop does not work.
>to install? It will be different from the XP on the restore/recovery CD.
Solution #3
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
The sticker says XP PRO but the key doesn't work.
I installed my copy of XP pro with my key and that works...but he is
not keep that one. I just wanted to see if that option worked, which
it did.
>>Thanks in advance
Solution #4
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Just to eliminate a silly possibility, the system originally came with XP Pro
and the sticker on the side for XP Pro? I ask simply because the product IDs
(keys) for XP Home and XP Pro are not interchangable... Ben Myers
Solution #5
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
lick expressed precisely :
There is a point system on installing windows XP to a computer, many
times the changing of a hard drive will require you contact MS by
telephone for a new install key.
When you install without the recovery disk using a different CD, it
comes up with a invalid key message, then choose the install by
telephone option, then use the change serial number option: type in the
number from your sticker, and it will provide you with the telephone
number to call.
Tell them you have changed the hard drive, and they have you read the
numeric number produced, and if valid they will provide you with a
numeric key to re-install...
However sometimes the bios is tagged, and you will still get the
invalid key message and no telephone number.
JR the postman
Solution #6
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
Do you have access to the Key that came with the XP Pro that you did try
Can you Help with these Keyboards and Mice problems?
Keyboards and Mice
i cannot open this websites in...
youtube, orkut Answer This...
Keyboards and Mice
Audio Failure From Audio Sound...
A younger nephew trying to... Answer This...
Keyboards and Mice
my logitech portable blue tooth...
i work in an alarm room w/... Answer This...
Keyboards and Mice
help turning off num lock
hi i am having problems with... Answer This...
Keyboards and Mice
Microphone not working Need...
I plugged in my Microphone and... Answer This...
Repair Service
Find Keyboard and Mice Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
