Question about RCA 25201RE1 Corded Phone
Changing displayed time on the phone
I would like to know how to change the time on the display screen.
Melody
  • luttermans Mar 09, 2009
    Jessepatrick's solution didn't even come close to answering my question. I solved the problem myself by taking out the batteries and calling the RCA phone by using my cell phone. When the display indicates the caller id the time automatically resets.
Thanks for that tip on removing the battery. I removed one for about five seconds and when I reinstalled it, there was no time displayed at all. A quick call from my cell phone, and the phone now shows the correct time. (Of course, now I wonder: would calling from my cell WITHOUT removing the battery first have had the same effect?)
Posted on Nov 02, 2009
Http://support.necunified.com/TimeChangeInstructions.pdf
Be sure that when you are putting in the time to put it in military time and put 00 on the end for the seconds. Ex If you are doing 8:14 am punch in 081400.
Posted on Mar 09, 2009
  • jessepatrick Mar 09, 2009
    sorry that the posted link didn't work for you. I used the directions posted and had my time fixed within 1 minute. I went to www.necunifiedsolutions.com and looked for the manual and used the information from that.
How to turn off music when turning on tv
Yes it is possible. You should be able to set the melody to off, low, medium or high
I believe you can get to the setting by doing this:
  • Press the MENU button to display the on-screen menu.
  • Press the up or down button to select "Setup", then press the ENTER button.
  • Select "Melody" by pressing the up or down button, then press the ENTER button.
  • Select the setting you want (Off) by pressing the up or down button
    repeatedly.
  • Press the ENTER button.
  • Press the EXIT button to exit.
You can find the manual here: http://downloadcenter.samsung.com/content/UM/200804/20080401185600828_BN68-01507A-01Eng-0328.pdf
Page 24/25 is where it talks about the Melody setting.
Sep 10, 2014 | Samsung LA22A450 22 in. LCD TV
Tip
Samsung Star GT-S5233 Secret Codes
<p><span>Here are some codes for samsung cell phone that can help you out in problem</span><span></span><br /> <p><span>*#06# Displays your IMEI </span><span></span><br /> <p><span>*#78# Test touch sensitivity</span><span></span><br /> <p><span>*#03# Displays a Unique number </span><span></span><br /> <p><span>*#7465625# Phone lock status </span><span></span><br /> <p><span>*#232337# Bluetooth MAC Address </span><span></span><br /> <p><span>*#1234# Software Version running on your phone. </span><span></span><br /> <p><span>*#2222# Hardware Version of your phone. </span><span></span><br /> <p><span>*#0228# Displays battery information. </span><span></span><br /> <p><span>*#0289# Melody test </span><span></span><br /> <p><span>*#0782# Displays the real time clock of your phone. </span><span></span><br /> <p><span>*2767*2878# Displays a Service menu</span><span></span><br /> <p><span>*2767*3855# , *2767*688#This code performs a full reset. </span><span></span><br /> <p><span>*#0842# Vibration test </span><span></span><br /> <p><span>*#0*# Speaker & LCD display Tests samsung security </span><span></span>
on May 14, 2011 | Samsung Star GT-S5233 Cell Phone
Tip
Turning off the Melody sound on a Samsung Television.
You have a Samsung television and you want to turn it on at night, and not wake up your house, or you are annoyed by the sound that the television makes when you turn the set on and off. Samsung incorporated a feature into the set that will play a melody to let you know that the set is either turning on or off, whichever the case may be.
If you want to turn off the melody you can follow the instructions below and that should take care of the annoying sound that is bugging you.
You may have a Samsung television and you remember when it had a melody when you turned it on and off and now that is gone. Well this tip can help you too. The same menu selection will allow you to enable the melody that is missing, and you can bring it back.
You can change the setting on your Samsung Television by selecting “Menu” then “Settings” and arrow down to “Melody”. There are four options; Off, Low, Medium, High. I personally would not select the high setting as it is very loud on my set. I guess if you have someone in your house that sneaks the television on and you want the loud melody to play, this could be a way of knowing when the set comes on. I hope that this helps you with your television issues and as always, Thank you for using FixYa.
I hope that you enjoy your television for years to come.
asnowman
on Mar 16, 2010 | Televison & Video
My nokia screen not working
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
************ CAUTION ************
if anything goes wrong,
then you can apply the master reset code,
that will NOT delete anything, ANYTHING from your
cell fone, but set each and eveything to its
default/standard setting ...
(likes, factory settings :-) )
the master reset code is:
#*7728#
Feb 14, 2012 | Nokia C601 Cell Phone
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Dark screen. My handset has dark screen I dont know why.
hello sir,
the back light of the screen in your phone seems to be affected.you should change the display screen of your mobile. this will fix this problem.contact the company dealer of your phone and ask them to change the display screen of your mobile.while changing try to go on with company.because some local service men will change the local display screen which already been repaired.which may cause the same problem in your future.this may help you to fix this. have a great time.
thank you
Jan 04, 2011 | Samsung SGH-E370 Cellular Phone
Touch screen menu not working
hi
the display gets affected. format your phone and try it . if still having problem change your display screen in your mobile.. the touch sensor may be affected in your phone. dont try to do it yourself. its great risk. contact your service provider to change the display screen. if your problem solved after changing the display . vote for this answer. im sure the problem will be solved after changing the display screen of your mobile
thank you
Dec 23, 2010 | Samsung SGH-A877 Impression Cell Phone
Reset code for samsung star 5233
*2767*3855# But be careful, it will delete all your phone memory including your contacts and other files..
Your can refer to the following codes follows:The codes are keyed in using the Keypad.
*#78# Test touch configurations , Sort of an Admin menu.
*#03# Displays a Unique number, specific for your phone I guess.
*#0289# Melody test
*2767*2878# Displays a Service menu.(seems like it contains all the goodies :D )
*2767*3855# Beware: This code performs a full reset. Use it only when you are screwed up.
Apr 30, 2010 | Samsung Star GT-S5233 Cell Phone
Directions for time change are misplaced. Do not know feature code.
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 15, 2010 | Nortel T7316E 2-Line Corded Phone
My phone has a very low sound that i cannot even hear it when it is in my pocket.It does not even vibrate in such a way that i can detect it.
you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
*#8999*8378#
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
then mine,
IF U R SATISFIED PLS VOTE ME
Jan 21, 2010 | Samsung SGH-E370 Cellular Phone
RCA 25201RE1 Corded Phone Logo
598 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
