Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
How to operate the defrost timer on a maytag msd 2456
Where is defrost timer reset switch on a Maytag mfd2561heb
This model Maytag has a defrost control board and not a defrost timer. Your control board is located at the top of your refrigerator behind the display.
Jul 28, 2016 | Maytag Refrigerators
Where is the defrost timer in MSD 2732 GR
Timer defrost motors are usually behind the bottom front grille.
Sep 29, 2014 | Refrigerators
I have a Maytag side by side refridge Model # MSD 2436GRW The refirdge side does not feel like it is cooling properly- I have had to move the dial up tp 8-9
There are many different ways a refrigerator will do this. But I will focus on the most likely and that will be either the 68233-2 Defrost Timer or the=> 61005989 Auto Damper Click Here=> MSD2436GRW_Controls and in that photo you will see the location's 13 and 8. Here are the instructions for testing the auto damper=> 61005989 Auto Damper Test Instructions Look into the rear of your freezer and tell me if ice or a layer of frost is covering the rear panel. If yes try to turn the defrost timer clockwise slowly untill refrigerator stops or manually defrost with a hair dryer. If the refrigerator defrost after turning defrost timer then just replace timer. Refrigerator will usally take 25 minutes after that time the refrigerator does not come on simply turn th timer clockwise until it starts. If defrost is not the problem then it is time to test the auto damper. There are a few other test like testing the defrost heater= HERE Here is the freezer compartment parts breakdown=> MSD2436GRW_Freezer_Compartment and part 12 in that photo is the=> 61006116 Defrost Heater Assembly with Defrost Thermostat
I will be here on Fixya or Here if you have questions, Thanks Sea Breeze
If helpful please rate this solution.. Thank You
Jul 19, 2011 | Maytag Refrigerators
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Where is the defrost timer in a maytag plus side by side also how do i test its operation
It does not have a timer it has a defrost board it is in the top of the frig in the back right corner under light a thermostat cover in a box and no they can't be advanced or checked.If the element is good and the thermistor is good than the only thing left is the defrost board and usually it is the board hope that helps
Apr 02, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
Defrost Problem
the first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Sep 12, 2008 | Maytag MZD2766GES Side by Side...
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Jun 10, 2008 | Maytag Refrigerators
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
90 people viewed this question
Top Hotpoint Refrigerators Experts
jasbo
jasbo
Steve Allison
Steve Allison
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
