Question about Toshiba Satellite L25-S119 Notebook
Hibernation My laptop has gone into hibernation (I must have touched a key by mistake) and now I cannot turn it on. What do I do?
  • cr248 Mar 09, 2009
    I did that but nothing happens
  • 404 Answers
Take the power out, take the battery out wait 2min and then power on
Posted on Mar 09, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 09, 2009
    is your battery charged? is the amber light on when you plug the charger or the battery light is on?
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
My hibernation option is gone.....
Hibernation may be disabled by default in XP.
Go into Start > Settings > Control Panel > Power Options. Click on the Hibernate tab, then check the Enable Hibernation check box to enable it.
You can start hibernation of your PC manually, if hibernation is enabled, by:
1. Selecting 'Turn Off The Computer'' from the Start menu.
2. Normally the left choice on the resulting pop-up window is ''Stand-By''. But, if you hold down the Shift key it becomes ''Hibernate''. So holding down the Shift-Key and clicking on the resulting ''Hibernate'' button (the left-most button) will cause your computer to start hibernation mode.
Note that many computers also have a button for starting hibernation mode also. Often pressing the Power button while the computer is on will cause it to go into Hibernation. (Sometimes desktop computers have this option disabled, but it can be enabled through some Setup menu item (unless a special key has been assigned to do it on the keyboard.)
Hope helpful.
Mar 18, 2010 | Compaq Computers & Internet
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
I hibernated my hp laptop and it refuse to come on again
Normall hibernation can resume from a selection of key / mouse touches.
Some of the HP's resume from the power button even though it is lit.
Sep 05, 2009 | HP Pavilion dv6000z Notebook
I have a LG lap top and its gone into hibernation
Disconnect the battery and replace then turn it on
Jun 05, 2009 | Computers & Internet
How do i get my siemens v2010 laptop out of hibernation.the screen has suddenly gone dark.the computer turns on and is fine, but you can only just see whats on the screen
You might have to restart the computer if it is stuck in hibernation. The best thing is to go to your settings and turn the Hibernation setting and sleep settings off. Go into your display settings to find this. Also when your computer starts look for the BIOS option to show on the screen to check the BIOS and make sure it is turned off there. To get to the BIOS hit the DEL key or one of the F keys to get into the BIOS. Do not password the BIOS of your Laptop. This can cause a lot of problems if you forget this password. It can not be recovered easy.
Jun 03, 2008 | Siemens Computers & Internet
Hibernation problem?
Press and hold the blue Fn key while pressig the F4
wait a moment and see if it wakes up
Nov 14, 2007 | IBM ThinkPad A31 Notebook
Toshiba Satellite L25-S119 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
