Question about Sony VAIO VGN-FS990 Notebook
Vaio vgn fs990 brought 7-28-06 no longer working. Battery at 0. This is even when plugged in. Daughter says the green light that used to show on the charger no longer on. ? Need a new charger or something internal? She is an international student in Australia, so hard to get more specific.
  • Nicolas
    Nicolas May 11, 2010
    Tell her to take the charger to an electronic shop and test if it charge before anything else.
My "sony vaio vgn txn15p"
if your Sony is older then 3 yrs I urge you to get a new battery. Make it last longer by draining the battery and charging it up everyday. This gives it a work out and helps it not get lazy.
May 02, 2011 | Sony VAIO VGN-TXN15P/W Notebook
A disk read error occurred Press ALT+CTRL+DEL to restart How to fix the problem
ur hdd has serious problem ITS BATTER TO BUY NEW ONE HDD... thanks
Oct 14, 2010 | Sony VAIO VGN-FS990 Notebook
Laptop won't charge
You might need a new could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing.
Apr 26, 2010 | Sony VAIO Notebook
How do you boot from cd on VGNfs990?
turn on the system and press F11 key when VAIO logo appears. If will give list of drives you can boot. select your cdrom drive from the list
Jan 14, 2010 | Sony VAIO VGN-FS990 Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Disk read error
If you receive this error in start up and your computer doesn't load windows. It was unable to read the disk.
Please use your recovery discs (or windows installation cd/dbd) to restore the computer. If the recovery discs don't solve the problem and you still receive the same error, the hard drive is possibly damaged. I would suggest to take the laptop to a professional for testing and fixing.
Thanks and good luck.
May 03, 2009 | Sony VAIO VGN-FS990 Notebook
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-FS990 Notebook Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
