Question about Epson Stylus C62 InkJet Printer
No electric getting to printer although I have change fuse, check socket and bought new lead Epsdon C62
  • 353 Answers
It sounds like you may have a faulty power supply or main board. If you wish to carry out further technical diagnosis, you will need to dismantle the printer. Please let me know if you wish to do this, by making a new post, and I will provide helpful information for this task.
Otherwise, you must take it to a technician for diagnosis and repair.
Posted on Mar 13, 2009
I replace the light bulb but it does not work although the dryer works fine. Is there a special bulb?
with the power unplugged, check the tab inside the bulb socket to be sure its not burned or damaged, also,, at times a new bulb is no good, If you have a multimeter,, put the selector to continuity ,, and place the black lead to the bulb base, and the red lead to the center point at the bottom of the bulb, if you get no reading, the bulb is no good, ( if you don't have a meter, screw it into another lamp, as long as your sure the dryer light socket is a 120v not a 220 volt
Jul 12, 2011 | Whirlpool GEW9250 Electric Dryer
Makes hardware sounds while its off
Although it is "off", if the power lead is still plugged into an electric power socket which is switched on, then there is still electricity going into the printer. So it will make sounds (mine does) but I'm not sure what it is doing, possible a self-cleaning routine?
Nov 18, 2009 | Lexmark X5495 Printer
Epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Feb 15, 2009 | Epson Stylus C62 InkJet Printer
Epson C62 printes only in blue
Since you haven't responded to our queries, I think we can say "Solved by Poster". If not, please respond with a new post to this effect.
Jan 13, 2009 | Epson Stylus C62 InkJet Printer
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Cleaning cartridge
Both the black and colour cartridge must be installed for the printer to work. So you will need two cleaning cartridges. If you only have one cleaning cartridge, make sure your "other" cartridge is not out of ink. If you are sure both cartridges contain ink/cleaning fluid, post a new comment with this information.
Nov 07, 2008 | Epson Stylus C62 InkJet Printer
What do i do??
did you install the installation cd given with your printer .......if you have installed then go to printer settings and make the change
Jul 03, 2008 | Epson Stylus C62 InkJet Printer
Xerox 4045 laser printer L2 and L3 errors
This has nothing to do with Epson C62 printers!
Apr 24, 2008 | Epson Stylus C62 InkJet Printer
Red "drop" shaped light blinking
On my C62 I it usually shows the "Status Monitor" when trying to print, which shows the levels for B/W & Colour.
If not go to CP/Printers, select the C62 (make sure ON) then Properties, then the Printing Prefs button (at bottom). The Main tab usually has this fill level indicator; also try the Maintenance Tab Status Monitor option. These are real awkward to find from scratch but useful when you get to know they're there.
Also if you remove and replace a cartridge you are usually given the option to say whether it is a new or old cartridge - choose new if you know it's nearly full. Don't take NO for an answer to their stupid questions!!!
Clwyd
Apr 15, 2008 | Epson Stylus C62 InkJet Printer
Epson c62 printer
I assume your new computer is Vista ?
You need the appropriate Vista driver
Epson or do a Google
Jan 15, 2008 | Office Equipment & Supplies
Epson Stylus C62 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
