Question about Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN, CALL SERVICE 6030:0159631
I can't advance past this error - can anyone tell me what it means ? Thank you in advance !
    Sniper:
  • 66 Answers
This error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Posted on Mar 21, 2009
Fs-4000dn error 0284232
Error should be something like CALL SERVICE XXXX:XXXXXXX.
First four numbers are error code, and numbers after : is a page count of device.
Write down first four numbers and maybe i can help you.
Feb 11, 2016 | Kyocera Fs-4000dn - Printer - B/w - Duplex...
Call service 7000: 0370082
Toner motor lock error**The top cover interlock switch is damaged and the top cover actuator side does not always seat properly. Replace switch (part of switch regulator pcb) and repair retaining clip
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
Call Service 7000: 0370082 Kyocera 4000dn
Toner motor lock error ,usuall ycaused by using non manufacturer toner ,you may need to get a new developer unit
Hi error code: Call service 6020:0053103 Can't
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Feb 14, 2011 | Kyocera FS-4000DN Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
LCD Displays "Call Service 7410:0089745"
This is a Drum unit non-installing error: drum is not installed or not installed properly. The durm PWB EEPROM does not communicate nor mally. Defective connection drum PWB(YC1) and Connect-L PWB(YC3). Maybe defective drum PWB EEPROM or defective engine PWB or itis just the drum unit itself is defective.
May 22, 2009 | Kyocera FS-4000DN Laser Printer
Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Feb 23, 2008 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer Logo
2,146 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
