Question about Gaggia Classic Espresso Machine
My gaggia classic frother is stuck and cannot turn the black knob
  • 137 Answers
Pull the knob to you, take it out than grab the valves axe with wrech or pliers, to prevent braking the black knob and open the valve.
after you opened it once it should work perfect.
ps these valves seal metal to metal and when thay stay long without working thay can do this.
Posted on Mar 31, 2009
Steam valve knob is stuck
The only reason for this I can think of is that the water has allot of minerals in it and they are depositing on the valve, use purified water from now on.
Nov 10, 2016 | Gaggia Coffee Makers & Espresso Machines
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
Milk does not foam
Look at the milk frother.
Ensure there is the end of the inner nozzle poking out.
If not remove the frother insert a pen and push the inner towards the end until a click is heard.
Job done.
Jan 23, 2010 | Gaggia Classic Espresso Machine
Cannot ventilate machine
Sounds like the milk frother is blocked.
Remove the frother completely,try to ventilate without it.
You should be able to see through the center of the frother.
If not try to clean it out with a paperclip or pipe cleaner.
Dec 27, 2009 | Gaggia Titanium Espresso Machine
You will need a new complete frother.
There a a few agents in brisbane under coffee machine repairs in the yellow pages.
North and southside of town
Oct 05, 2009 | Gaggia Classic Brushed Stainless Steel...
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Jan 07, 2009 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
200 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
