Question about Sony Cybershot DSC-H3 Digital Camera
Sony cybershot takes black pics
Hi
i have a sony cybershot and it's taking black pictures,. the lens opens and the screen is working perfectly, but when i snap for a pic, i get a black result. any ideas?
    President:
  • 1,223 Answers
It seems like CCD failure to me bcoz if everything is working and u get black pics it sounds like this , pls go for warranty claim if u have one otherwise contact support centre in ur area they will replace the CCD for a charge , i am not sure abt the price pls rate me even i was unable to solve ur problem remotely bcoz it is a hardware failure which nobody can help
but i am pretty sure about it
regards
Posted on Mar 09, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais Mar 09, 2009
    they might do it free of charge pls ask them even if u r out of warranty bcoz sometimes they have these series on service advisory list pls check it first b4 accepting any charges
  • Shoaib Rais
    could u pls try to initialize first i mean factory default settings have u tried the procedure to factory reset the camera
    following is the link for service and support
    http://eservice.sony.com/webrma/web/vali...
  • Shoaib Rais
    ok try this pls take out the mem stick b4 going fwd
    Home Screen>Settings>Main Settings1>Initialize press OK on
    Control Button and then OK select Initialize All Settings press OK
    then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
    after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
    pls let me know with the results
    Rate me FIXYA if i fixed ur problem
My Sony cybershot dsc-w55 won't take pictures! I
Your lens is stuck due to either being banged or bumped or there is dirt/grit inside the lens gears. The lens needs to be replaced, but buying a brand new lens is out of the question. Sony will charge $125 just for the lens assembly, it's crazy.
A refurb lens can be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Sony Cameras
Sony Cybershot DSC-T200 dropped, screen black so
the display is been broken...you can get the one from customer service...
Feb 22, 2010 | Sony Cybershot DSC-T200 Digital Camera
When i turn on camera say rec folder is 101msdcf screen is black can't take pictures
You need to got to your settings on the camera and format the memory stick. After that, you will be able to take pictures .
Feb 13, 2010 | Opteka (OPT32H1) (3.2x) for Sony CyberShot...
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My touch screen is broken on my Cybershot DSC-T50
do you still have that camera?
I broke the lens on mine but everything else is working, could we make an arrangement?
Sep 04, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Pics show up black
Camera is already fried / damaged so take it apart and do some research on lens specially on shutter built in lens mechanism.
Jan 10, 2009 | Sony Cybershot DSC-T200 Digital Camera
Flashes, lens open, not plugged in, wont take a picture.
Its is issue of bad ccd imager and this part needs to be replaced for live view to take picture with DSC-T1.
Sony will repair your DSC-T1 free of cost as per announced scheme for ccd problem.
Click Sony CCD Support for details.
Dec 22, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
My sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
Apr 07, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cybershot DSC-W90
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Jan 14, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
162 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
