Question about Dell Vostro 1510 Laptop
I am having problem with window startup - Dell Vostro 1510 Laptop
  • kuldeeprawat Mar 09, 2009
    it take long time to startup process
  • ianwrkk May 11, 2010
    what exactly is the problem you are having?
  • 56 Answers
If it is only the start up that takes a long time, but then it works fine you should go to start/run and tipe in msconfig
then click on the startup tab and deselect everything except antivirus.
then reboot the machine. a window will open up about the utility being used put a check in the box so it doesent tell you again and you should be starting up quite a lot quicker.
you could probably do with some more ram as well
Posted on Mar 09, 2009
  • 404 Answers
And you expect help with that attitude, explain with further details man
  • lotfi bouakaz
    lotfi bouakaz Mar 09, 2009
    and you expect help with that attitude, explain with further details man
How to Add Programs in Windows Startup?
Programs or shortcuts placed in the Startup folder will run whenever Windows starts.
  1. Click the Start button , click All Programs, right-click the Startup folder, and then click Open.
  2. Open the location that contains the item you want to create a shortcut to.
  3. Right-click the item, and then click Create Shortcut
Oct 19, 2016 | Computers & Internet
How to disable/enable Microsoft Windows startup programs
In this guide I will show you how to enable or disable startup programs in Microsoft Windows. Disabling startup programs can help your computer boot up faster and remove some of that garbage that clusters your desktop when you first boot up your computer.
In Windows go to Start and click Run. In the Run box type "msconfig". You will now get a new window that opens up like below,
Click the "Startup" tab. In this tab you will get a list of programs that will launch when Windows starts up. The more programs that start up, the slower your machine will be. You can speed up your computer boot process by disabling unnecessary programs. To disable a program, uncheck the box next to the program you wish to not startup. Some examples of unnecessary programs are Itunes, Google Talk, Skype, software updater programs or any other programs that you don't wish to be started when Windows opens.
Alternatively, you can enable certain programs to startup when Windows boots. Just check the box next to the program you wish to startup.
Make sure to hit the "apply" button once you are done!
I hope this article was informative.
on May 19, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
After I power on HP Hewlett packard laptop what keys can I use to access startup menu
If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
May 12, 2015 | HP Computers & Internet
My Presario CQ60 is stuck in recovery manager mode. I keeps going to startup repair.
Problems starting up a PC can be tricky to fix, since Windows hasn't had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair can prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from starting.
Startup Repair is designed to start automatically if Windows detects a startup problem. For more information about using Startup Repair, and what to do if it doesn't start automatically
here is my solution... when you boot your window when you're middle in dos loading press F8 and select boot in safe mode... then when you are in windows click start --> all programs ---> accessories---> sytem tools ---> system restore... hope you back up your windows.... try to restore your window in earlier time...
Jun 27, 2011 | Compaq Presario CQ56-115DX Laptop
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
My computer is trying to configure and load windows photo gallery but it keeps saying I do not have the CD Rom I do not want to load this program I cannot seem to cance it and when I go into remove...
  • Click Start .
  • In the Start Search field, type msconfig, and press Enter.
  • The System Configuration window opens.
  • In the General tab view, select Selective Startup, and remove the checkmark next to Load startup items.
  • Click on Startup TAB
  • Under Startup TAB uncheck all of the Items except Following:-
  • For Windows Vista
HD Audio Control Panel.
Hp digital imagine - hp all-in-one series.
HP Total Care Advisor.
Microsoft Windows Operating System.
NVIDIA products.
Symantec Technologies products.
Windows Defender.
  • For Windows XP, do not disable the following startup items:-
  • Click the Services tab, select Hide all Microsoft services, and click the Disable all button.
  • Restart the computer for the changes to take effect.
  • After the computer restarts, a message appears confirming some startup programs have been blocked from opening.
Jul 04, 2008 | Computers & Internet
MS WIndows Startup Clean Up
Click Start > Run > msconfig > click Startup Tab and then go through the list. Items that are checked will startup.
Jun 30, 2008 | Microsoft Windows XP Home Edition
remove it from start up
start > programs > startup right click and delete the program
if the program is not in the startup the you have to go into the registry with regedit
Jan 04, 2008 | Microsoft Windows XP Professional With...
Dell Vostro 1510 Laptop Logo
44 people viewed this question
Alun Cox
