Question about Microsoft Computers & Internet
NEED A HELP
I want to know that how that how to give password to a FTP server to secure a data
I also want to know about GPEDIT.MSC a group policy managment , that by doing each setting what will happen
You can contact me on 9004334177 / 9769749111
If u can give me ur mobileno. then plz mail me ur no
please do the needful ASAP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
HOW TO REMOVE GROUP POLICY FOR USEB RESTRICTION FOR CLIENT USER
You will need administrative access to modify any group policies.
From the command line run gpedit.msc. Since you are not listing a particular group policy I can only suggest that you bring up all settings, and then sort them by state. All enabled policies will rise to the top of the list. You can then disable or modify the policies as needed.
May 12, 2014 | HP Computers & Internet
To restrict saving files on desktop
Look for in Group Policy. Start > Run > GPEdit.msc. Good luck.
Aug 07, 2012 | Microsoft Windows Server Standard 2003 for...
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Features
Group Policy Manager
Forest: ...
Computer configuration
Policies
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
Also
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
All work of gpedit.msc
Although the Group Policy Editor console (gpedit.msc) is mostly used by administrators of networks and domains, it also has uses for a stand-alone home computer. One application is to allow convenient and easy editing of the Registry so that a variety of tweaks or changes to the system can be made. These settings are known as policies and are stored in a special hidden folder
Sep 15, 2009 | Microsoft Windows XP Home Edition
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
---> System
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
Gpedit police
AMSv2010 is now Available in my Web
Visit: http://naldo-project.weebly.com
It's a True Windows Solutions 100% Secure and Tested
Over 500 Administrator Restriction and Secret, Video Capture, iPod, Secret Panel, Internet Explorer Inside, Windows Registry, Windows Service, Restrict Devices, Backup Options, Screen Capture, User Manager, Legal Notice Caption and Text, System Information, Control Panel, Delete Files, Copy & Paste, NotePad, View IP, Windows Time, Keyfinder, Memory Information, Ad or Remove Programs, Startup List, View Restriction from System and Explorer, All Groups Policy Management (GPEDIT), All MMC Restrictions, Shutdown Timer, Shutdown, Hibernate, Restart, Logoff, more..., MDI Parent View Option, Task Manager Inside, Keyloger, Hidden and View Files, See the Video... more... more... more.
* Protect this Software with Password and Secure Password, Startup Option, Icon Tray Option*.
It's a Administrator Perfect Software and Tool
***Recommend this program to your friends***
by Naldo (AMSv2010 Developer, Designer, Author) Future MVP ((Most Valuable Professional) / Puerto Rico and Expert in Administrator Restrictions for Windows XP PRO, HOME, Vista and Windows 7 BETA in test and specifically to test Windows 7 has several restrictions.
Jan 13, 2009 | Microsoft Windows XP Professional With...
UNABLE TO OPEN GROUP POLICY EDITOR
I'd suggest downloading and installing the Server 2003 Administration Tools. There were updates to several over the course of the last two service packs and may fix your problem. They are downloadable via http://www.microsoft.com/downloads. Do a search for Administration tools or adminpak.msi
Jan 23, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
