Your coffee machine is wrong position of distribution.you must take photo before
dismantle., also have water leaking at the distributor. just change all this items. Good Bless
Joseph
It is probably blocked or dirty inside. Try cleaning tablets other wise see the other posts for cleaning the pressure valve inside the machine.
SOURCE: Machine Fault Error No 06
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
One thing I have found is that the used coffee builds up inside the machine and the head can not move. Open the machine's top so you can see the iner workings, you will see the main head and below that a well, this wel should be empty, on mine it was full of old compated coffee, use a chopstick or fondue fork and get all the old stuff out... after that no problems with error message. Still got a leak..... anyone ?
