Question about GE Profile Spectra JGBP90 Gas Kitchen Range
"Locked Door"light The "Locked Door" light won't go away and there is no 'latch' to unlock the door. How do I get the light off so I can use the oven again?
  • 1,031 Answers
There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch may solve the problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. usually located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should feel a click.after Reassemble and power up.
hope this solves the problem do let let me know i will appreciate a fixyaa rating thanks and Godbless
Posted on Mar 09, 2009
My oven is locked. Display shows F5:E7 How do I unlock it?
Vera, Code F5 E7 your latch assembly has failed. Turn oven breaker off to the unit for 5 min. to see if it will reset. If not, then try to set the self clean, wait 1 min. and cancel it to see if that will reset the door latch. If it does not reset the door lock, then you will have to manually open the door and replace the door latch assembly. It's not easy task to unlock the door. You'll need to use a coat hanger and pull the latch assembly from (right - left) by slipping it down between the door and the oven top. Force the latch over to the left and open the door, then you will have access to remove latch.
press the helpful button and follow me on fixya for more tips and info
Appliance411 FAQ After self clean range oven door won open
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwj-qYvv3ffKAhVHKh4KHdaUBgAQtwIIKTAD&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D320yZMp34oA&usg=AFQjCNE0dH2xRKfdY8alz0y7MdjMT86ULA
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16246
How to Troubleshoot the Door Lock on your Stove Range
Feb 14, 2016 | Kitchen Ranges
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
Jennair jer8855 range was beeping , had f9 message, oven door locked and oven won't turn on. I turned circuit breaker on/ off as per a previous post which took away error message, unlocked oven do
The latch has most likely become dislocated from its mounting points and will need to be secured back in place correctly.. Check the mounting screws to see if they are loose. Then move the latch back into position and tighten them securely. If not then the error will just come back. The latch mechanism may also need replacing altogether itf it is damaged.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 08, 2012 | Jenn-Air JER8855 Electric Kitchen Range
How do i reset the locked oven door to unlock it?
I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
http://www.geappliances.com/search/fast/infobase/10000161.htm
Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
May 16, 2011 | GE JTP15 Electric Single Oven
Oven door lock does not unlock, I turned on the self clean mode and then changed my mind and turn it back off about 3 minutes later. But it does not unlock. The lock light is blinking.
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 26, 2009 | Electrolux E30DF74PS Dual Fuel (Electric...
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
203 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
