Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & Paykel GW612 beeps before spin.
I suspect I have an error code 42 (not the meaning of life).
The control panel has a group of 5 wash lights and three spin lights.
The pattern is 0x000 0x0 (Where x is on).
The machine got to this point and stopped - switching power off for a while does nothing - when powered on it just goes into the beep cycle. Pushing any button silences the beep but that is all. Tried to hold power down for > 60 seconds but this did not fix it.
If I push the pause button the lights go out - and the lid locked light comes on - but no lid lock noise.
I have a feeling it may be the lid solenoid but can anyone advise?
Stan
  • 144 Answers
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Posted on Mar 24, 2009
Hi I have a F & P washing machine GW612. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Here is the instructions manual which contains the detailed diagnostic code explanations from p.33 on.
http://laundry.manualsonline.com/manuals/mfg/fisher_paykel/gw612.html
Aug 26, 2015 | Fisher and Paykel Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
F&P gw612 error 368
if the x represents light on then that fault code indicates pump fault.It's blocked or over heating
Feb 13, 2014 | Fisher and Paykel Washing Machines
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
F & P Washer GW612 Wont drain fully unless you repeat spin a couple of times and then wont rotate have taken motor to be tested was (low?)Have replaced no improvement First and fourth light flash and...
Kate - firstly the windings of the stator when measured is 32 Ohms, earlier models was a lot lower between B-Y-R.
The washer will pump - rest pump (Cycles) during the spin cycle, if however it overheats then water will not be fully pumped out. A possibilty is the hose into the drain or sink is too high, or blocked somewhere.
In most cases the washer will indicate an error code.
The LEDS 1st & 4th from the right im assumming 10010000 = Fault code 144 - either you have a loose connection under the display/push buttons panel or you have a faulty motor control module
May 11, 2011 | Fisher and Paykel Fisher & Paykel Washer
Hi I have a gw612 Fyscher and Paykel 8 years old. It is now refusing to start and the led lights when I turn it on are the third and the fourth wash cycle lights as well as the spin light. If I press start...
Hi just read your posting.Starting from the left to right if the lights that are on when the machine is beeping are the 3rd and 4th and 8th then the error code is called COLD VALVE FAULTY.This means either your cold water valve is faulty or you control module is faulty.Would you like me to guide you in the testing and isolating the fault and replacing the faulty component?Please reply for further help.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Tub fills but there is no aggitation model gw612
Hi just read your posting,Now, does the machine show an ERROR CODE and beeps?If it does show an error code it will be in a number in your LCD DISPLAY if you have that model or a series of lights will light up.Now these lights will be in a row of 8 lights.Starting from the left to the right which ones are lit when the machine beeps?Is it the 2nd and 4th or the 1st and 5th ---etc---?Please reply with additional information and I am sure I can help you.
Aug 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel gw612 fault 0000X0X0 can any one help X is light on on control board
click on this link directly to get the user manual of your product http://safemanuals.com/user-guide-instructions-owner-manual/FISHER%20%2526%20PAYKEL/GW612%20-_E in this link there is mentioned all types of troubleshooting and error code list. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 30, 2009 | Fisher and Paykel Washing Machines
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,151 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
