Question about HP COLOUR LASERJET CM4730 F MFP Printer
Display frozen on "initiating scanner", start button illuminated
Does not clear after cycling power
    Problem Solver:
  • 16 Answers
Turn off, hold down 6 button and keep holding while turn on. Wait for the three lights to stay on then hit the 3 button to scroll down to COLD RESEt and touch 6. It should restart itself and possible fix it.
Posted on May 14, 2010
  • Manuel Ribeirinho May 28, 2013
    Thanks, but does not work. What 3 lights do you mean? I have to be long to hold the button 6?
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
Reset scanner
Please try this:
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
I cant reprogram the scanner. It is only in channel 6
To restore normal operation, try RESETTING the scanner:
- Power the scanner OFF, then power it ON again.
- Insert a pointed object, just as the end of a paperclip, into the RESET opening on the side of the scanner, then push the small button inside the opening.
In many cases, the RESET will restore operation. If not, you'll need to perform the more drastic INITIALIZE process. NOTE: INITIALIZE will erase all information that you've programmed into the scanner and restore it to original factory settings. To INITIALIZE the scanner:
- While holding sown the TUNE/CLEAR key, press the RESET button as above. The scanner display should shut off.
- When the display turn on again, release the TUNE/CLEAR key.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
May 22, 2010 | Radio Shack Pro-82 Scanner
I cleared my pro-82 scanner. Program button is not working to let me reprogram. Help.
As long as all frequencies have been cleared, try initializing the scanner. This will return everything to the original factory settings.
To INITIALIZE:
- Turn the scanner OFF, then switch it back ON.
- Hold down the TUNE/CLEAR button.
- While continuing to hold the TUNE/CLEAR button down, insert a pointed object such as a paperclip or the tip of a pen into the RESET opening on the side of the scanner, and press the RESET button inside the opening. The display should go blank.
- When the display comes back on, press the TUNE/CLEAR button again. The scanner should now be ready to accept programming.
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 08, 2010 | Radio Shack Pro-82 Scanner
Scanner problems Its stays on Auto-Scann and buttons dont work
Resetting or initializing the scanner may clear your problem.
To RESET the scanner:
- Turn the power OFF, then turn it ON again.
- Insert a pointed object (paper clip end, ballpoint pen tip, etc.) into the RESET opening on the side of the scanner, then press and release the button inside the opening.
If the above doesn't clear the problem, try the more drastic INITIALIZE procedure. NOTE: this step will erase all data that you have programmed into the scanner and restore it to original factory settings. To INITIALIZE the unit:
- Turn the scanner OFF then ON again. The scanner briefly displays the DSP boot version, then "Welcome to Digital Trunking" displays.
- Press "0". The scanner displays "System Tests Select Test Exits if no Key Press"
- Press "1". The scanner displays "Factory Unit Erase Memory ENTER if Yes CL to Exit"
- Press ENTER. The scanner displays "Initializing Clr Main Mem V-Scan is OK Please Wait"
- Do not power the scanner OFF until INITIALIZE is complete. When the process is complete the scanner will display "M0000" on the top line and "Bank 0 Ch 0" on the bottom line.
If neither of the above steps works for scanner I recommend that you take it to your nearest Radio shack and arrange certified repairs.
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Apr 21, 2010 | Radio Shack Pro-96 Scanner
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I do a master reset on the pro 83 scanner
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
BillB
Feb 08, 2010 | Radio Shack Pro-83 Scanner
All channels locked
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
BillB
Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
My pro-2096 does not display any letters or
To RESET:
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
HP COLOUR LASERJET CM4730 F MFP Printer Logo
187 people viewed this question
Ben Johnson
