Question about Miele 24 in. G645SC Plus Free-standing Dishwasher
Where can I buy new drying fan for Miele Gold 2000sc dishwasher
Bought dishwasher when I lived in belgium 9 years ago. Fan has failed |(part No IMS M45/13 cod 52504.11). Where can I buy a new fan ?
5 Suggested Answers
  • 3 Answers
SOURCE: Dishwasher fan fills with water
Well, I just took my hose out (pulled both ends off the connectors) and it was indeed full of junky cruddy muck, so blew it out over a waste bin until it ran clear through. Now I've put the hose back on and will see what happens next wash!
Posted on Oct 22, 2008
  • 14 Answers
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
  • 177 Answers
SOURCE: The drying vent on the front of our miele
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
Posted on Mar 02, 2010
vpsoccer
  • 269 Answers
SOURCE: Hi Service, I have a Miele
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Posted on Jan 26, 2011
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
Jan 16, 2011 | Miele Dishwashers
Our Miele dishwasher has started to make a noise when the drying cycle starts, 25 mins from the end of the programme. Sounds like a the fan bearing or, because it's pretty new, maybe it's obstructed or...
And do you get a pool of water on the floor when you open the door and the fan drains out? If so, then you have the Miele problem.
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked before.
Nov 27, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
Miele Dishwasher - Not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
xxz
Apr 26, 2010 | Miele 24 in. G892SCU Plus Built-in...
The drying vent on the front of our miele dishwasher is leaking water and the fan is making a lot of noise at the end of cycle
Feb 05, 2010 | Miele 23 in. Novotronic G841 Built-In...
Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Jun 21, 2009 | Miele G848I Dishwasher
Does Not Dry Dishes
Withe the model and serial number it appears that this dishwasher is less than 2 years old.
Your symptoms point to a failed heating element. That is kind of surprising because this dishwasher ~should~ report an error code if the thermistor does not detect the raising temperature from the heating element.
The LG LDS and LDF models do NOT turn on the heating element in the drying cycle. It turns it on during the final rinse and the dishes dry as the built in fan runs.
So, I suspect the drying fan and related gear is inside the door panel. Do a load of dishes and listen for the final rinse to drain. Then, listen really closely near the top of the door for the quiet sound of a fan _and_ place your hand underneath the left hand side of the closed door for warm air blowing straight down.
If you do not hear./feel what I discribed , the drying system has failed. OH, and if you have any water leaking from the door (right where the warm air is supposed to come out, contact LG service folks and firmly request that they replace the drying parts with a retrofit kit.
Please review this and tell me what works and what questions you still have.
Good Luck and please keep me posted! OK?
Mar 24, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Dec 31, 2008 | Miele 24 in. G865 Built-in Dishwasher
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele g 665
it is the "FAN" inside the door, i had that problem too.
if it leaks after you open it when it stops and the door is on the ground.
You can open up the front and clean the black small tube witch comes from the fan on the left upper side (if you're in front of the machine) and down to the magnet opened valve.
On my Machine i replaced the tube with a new one as you don't get everything out.
Meins321
Mar 23, 2008 | Miele 24 in. G693 Free-Standing Dishwasher
Miele 24 in. G645SC Plus Free-standing Dishwasher Logo
64 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
