Question about Toshiba 28N33 28" TV
The colour has gone wrong on my tv it show the the green and blue pigment but not the red. wil this be an expensive repair?
  • redden71 Mar 12, 2009
    Cheers dan, the problem is now fixed.
    Den
  • 4,234 Answers
This problem could be as simple as poor solder connections on the board that sits on the back of the CRT to a defective driver transistor for the red gun to a bad picture tube. It is possible that this is an inexpensive repair (solder connection or defective transistor) or expensive (bad tube). If you can solder, try resoldering the CRT board connections and see if that resolves the problem. If not, then have a shop take a quick look. They will be able to determine whether the CRT is bad or not.
Dan
Posted on Mar 09, 2009
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Colours on tv screen have gone green in colour
If you have used the red, green and blue video cables, the your red is either damaged or loose. If yuo used the regular red, white and yellow AV cables, the yellow is loose or damaged, In either case, if the cable is not loose, you'll need a new set of AV cables
Nov 27, 2009 | Nintendo Wii Console
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Jul 20, 2009 | Thomson Televison & Video
Toshiba colours gone wrong
Yes it is repairable. One of two things is wrong. The color wheel is going bad or the DMD board is going bad. These are the most common repairs needed for a Toshiba. I hope this will help.
Mar 23, 2008 | Televison & Video
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Help,colour is wrong
Hi. The problem is either the degaus positor has failed which is an easy repair. Or have you recently placed hifi speakers or something with a strong magnet in side near your tv set.
Jun 04, 2007 | Bush 5693D 24" TV
Toshiba 28N33 28" TV Logo
200 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
