Question about Acer Aspire L100 PC Desktop
My Acer Aspire L100 will not boot up - Acer Aspire L100 PC Desktop
    Genius:
  • 2,785 Answers
Plz try by resiting the ram
Posted on Mar 09, 2009
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I need boot files on a USB to boot up my acer aspire L100 can help with this. Paul
    secure an os that is capable of using usb boot like windows xp portable.
    Apr 18, 2011 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    I have a Acer Aspire L100 and would like to restore to factory settings please help
    If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
    http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
    Apr 11, 2010 | Acer Aspire L100 PC Desktop
    Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
    Dear sir
    if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
    simple.. if u need more help please contact feel free.. thianks..
    Dec 15, 2008 | Acer Aspire L100 PC Desktop
    Aspire L100 sudden death
    have you tried all video outs?
    maybe the harddrive has cooked?
    try another harddrive or boot from a cd, if it can boot from cd maybe an install cd or rescue disk Linux cd, does'nt matter, just a test to see if system will boot.
    if so harddrive is most likely bad or setup incorrectly.
    if not and you still hear noise from the machine could be video out/graphics chip.
    of course there are other things that can cause these symptoms best bet is to contact ACER this is really the only course of action after trying these things, they may have records from other buyers recognising the problem from the level of complaints, and forthcoming to a solution.
    if all you people with this problem cooperated/collabarated by making contact with Acer then they would surely see that maybe there is a problem, in saying that/this extensive testing would need to be carried out to ensure that these systems are suffering the same hardware malfunction. time versus worth?
    these are the places i would look
    CleanPC
    Nov 02, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 heat problem
    go into the BIOS and disable the smart fan. The next boot will allow the fan to run at full speed, approx 7200rpm instead of 2800 rpm and the machine will not overheat. However, its will sound like an aircraft on takeoff!
    Oct 20, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    237 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
