Question about Cisco PIX 515E Firewall
Pix 515E inside to outside translation problem
Dear Sir,
We need your assistance to resolve our problem. Attachment file is the running configuration for your reference. This is regarding the PIX 515 E firewall.
The Problem is as follows:
Scenarios are: we have two different ISP, both the links are working fine if we terminated into cisco Router 2800. If I terminated the ISP 1 Link into Pix firewall. Almost last ten days there is no issue. Internet working fine in the inside network. But from the last two day I have facing a problem that I can access web sites in the Firewall. But not in the inside Network. If I change the ISP 1 link to ISP 2 Link . It is working fine. I can access the internet in inside. Nothing I had changed. Only the connectivity and the IP address. But we need to run the ISP 1 link in the firewall. Please suggest the necessary changes for successful running of the link from inside also.
ISP 1 Link address Details :
ip address outside 203.193.129.132 255.255.255.240
global (outside) 1 203.193.129.133
route outside 0.0.0.0 0.0.0.0 203.193.129.129 1
ISP 2 Link address Details :
ip address outside 121.246.145.170 255.0.0.0
global (outside) 1 121.246.145.173
route outside 0.0.0.0 0.0.0.0 121.246.145.1 1
Awaiting for your quick response.
Regards,
D.Kiran Kumar
STPI-Warangal
    Problem Solver:
  • 5 Answers
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Posted on Mar 13, 2009
How do I send a photo to Amazon for a photo mug please?
save pix to your hard drive.....(click on save pix).....then click on attachment when sending email to Amazon.....then the list of saved files on your hard drive will pop up then select the pix you want sent.
Nov 23, 2014 | Coffee Makers & Espresso Machines
Freezer runs and sides are hot
Good Morning bigred140, thank you for allowing me to assist you!
From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around your refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can typically locate one on the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your freezer) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Best regards, Chris.
Dec 22, 2013 | Frigidaire FKFH21F7HW Freezer
I can't open attachment to email. the remarks " click to run configuration failed" appear on the screen when i try to open files or downloads
What is the file format that you are trying to open? Do you have the proper software to open the file type?
Nov 13, 2012 | Computers & Internet
Sir i got a message from Hitachi company how to download call letter sir Reply.
sir i got a message from Hitachi company how to download call letterby link:-yourfilelink.com/get.php?fid567848
Sep 04, 2010 | Computers & Internet
I am able to get the attment from a particular sender
Please explain your question further ...
"I am able to get the attment from a particular ... "
a particular what?
If you are unable to receive a particular attachment from an individual, it depends on the attachment. Microsoft Outlook Express strips attachments of Microsoft Files. That is if someone sends you a MS Excel spread sheet or Word document, Outlook Express will strip the attachment for security. There's no way around this. The fix is have the person send you their file in .ZIP format. Then you can unzip it locally.
Sep 02, 2009 | Microsoft Outlook Express
How to reset password of pix 506e
You only need a PC and a serial terminal. First of all you need to know the PIX software version you run. After that you must go to Cisco web page and get from there the utility for the password recovery corresponding to your version of software.
After that you must connect to the PIX console port. Press ESC key after the PIX is booting and a special prompt it will appear (monitor>). Issue the "interface" command to specify which interface to be active. Inside interface it will be the default one. Then use the command "address" to go with the IP address of the above interface. After that, you will need also an TFTP server where you must upload the software utility specified in the beginning of the solution (the one downloaded fron Cisco). After the "address" command, issue an "server" command to put the IP address of the TFTP server. Than, use the command "file example.bin", where the example.bin is the file downloaded from Cisco. Maybe you will need also to specify the gateway of your network. This you can accomplish by using the "gateway" command. Finally, use the "tftp" command to start the download.
The default Telnet password after this process is "cisco."Go into configuration mode and issue the passwd your_password command to change your Telnet password.
Best regards,
T
Apr 24, 2009 | Cisco Computers & Internet
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
I need a L2TP configuration for my PIX 515 and ASA 5505
You can do this, For your ref i hv given you a link
http://channel9.msdn.com/forums/9GuyAroundTheWorld/251722-Cisco-Pix-to-Windows-Vista-Native-Client-Using-L2TP-IPSec/
Mar 01, 2009 | Cisco ASA 5500 Firewall
How do I acces an pst file with te email that comes with Window Vista?
You need to download or open the attachment file with the PST file.
You also need to have Microsoft Office Powerpoint installed on your computer.
If you do not have office you can download the following software to view PST: Download details: PowerPoint Viewer
Oct 27, 2008 | Computers & Internet
I am trying to use the fax program included in Windows XP but am having trouble downloading the appropiate files.
Dear Sir:
Please click on the links below:
http://support.microsoft.com/kb/306550
and
http://www.microsoft.com/windowsxp/using/setup/learnmore/crawford_02october21.mspx
There are many things involved in this, if the issue still persists after going through the above links, please reply to me so that we can chat and resolve the issue.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 02, 2008 | Computers & Internet
Cisco PIX 515E Firewall Logo
385 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
