Question about Lexmark X7170 All-In-One InkJet Printer
X7170. Scanner not working
Recently the scanner stopper working. Everything else is fine. I do not wish to buy a new machine as I have several full ink cartridges left for this one. Is it worth having this one repaired.
I'm having the same problem and don't have a solution. Lexmark tech support is no help at all. All they offer is a discount on a new model.
I have taken the scanner apart, checked the
Posted on Jul 27, 2012
    Problem Solver:
  • 10 Answers
Scanner bulb might be burnt out, not hard to fix if you can get the part not worth paying someone to fix though. can buy 1 right now from consumer depot online for $19.00 plus $32.00 for shipping
Posted on Mar 17, 2009
Plustek Optipro 9636T - working under Windows 7.
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
Aug 20, 2017 | Plustek OpticPro 9636T Flatbed Scanner
I have a Lexmark x7170 3 in 1. I got a new-ish laptop with Vista and now my scanner doesn't work. I've tried download drivers, but nothing seems to work. Are the compatible at all?
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Sep 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
The scanner no longer works on my X7170. It used to work just fine. Wondered if I had a setting change or something. It will copy no problem.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the everything turns back on, reconnect the printer into the computer. Wait for your computer to fully recognize the usb connection. Try to scan again.
You can also try to update your printer driver. Just insert the installation disc into the pc hard drive and run the setup application.
Jul 19, 2011 | Lexmark X7170 All-In-One InkJet Printer
Describe how to put the scanner wire in taskalfa 221 copier
Fitting the scanner wires
NOTE:
When fitting the wires, be sure to use those specified below.
Machine front: (P/N: 2C91236), gray
Machine rear: (P/N: 2C91235), black
Fitting requires the following tools
Two frame securing tools (P/N 302C968310)
Two scanner wire stoppers (P/N 3596811)
Procedure
1. Remove the rear cover.
2. Remove the screw and remove the scanner wire drum gear from the rear side of themachine.
3. Remove the stop ring and bush.
4. Remove the stop ring and bush from the front of the machine.
5. Remove the scanner wire drum shaft from the scanner unit.
6. Insert the locating ball on each of the scanner wires into the hole in the respective
scanner wire drum and wind the scanner wire three turns inward and four turns outward.
With the locating ball as the reference point, wind the shorter end of each of the wires outward.
7. Secure the scanner wires using the scanner wire stoppers.
8. Refit the scanner wire drum shaft to the scanner unit.
9. Insert the two frame securing tools into the positioning holes at the front
and rear of the scanner unit to fix the mirror 2 frame in position.
10. Loop the outer ends of the scanner wires around the outer grooves in the pulleys on the mirror 2 frame, winding from below to above.
11. Hook the round terminals onto the catches inside the scanner unit.
12. Loop the inner ends of the scanner wires around the grooves in the pulleys at the left of the scanner unit, winding from below to above.
13. Loop the scanner wires around the inner grooves in the pulleys on the mirror 2 frame, winding from above to below.
14.Wind the scanner wires around the grooves in the scanner wire guides at the left of the scanner unit.
15. Hook the round terminals onto the scanner wire springs.
16. Remove two scanner wire stoppers and frame securing tools.
17. Focusing on the locating ball of the wire drum, move aside the wires to inside.
18.Move the mirror 2 frame from side to side to correctly locate the wires in position.
19. Put the mirror 1 frame on the scanner rail and move it toward the left side of the machine.
20. Insert the frame securing tools into the positioning holes (leftmost holes) at the front and
rear of the scanner unit and screw the mirror 1 frame while securing both the mirror 1 frame and the mirror 2 frame.
21. Remove two frame securing tools.
22. Refit all the removed parts.
I hope this is helpful,
Shawn
Mar 03, 2011 | Kyocera Copystar 221 Black and White...
Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Everything seems to be working fine excepts for the scanner any suggestions?
Dumo the machine and buy a new one the scanner replacement cost is almost 200.00
May 25, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Snapscan 1212u and windows 7
I have found out the hard way that Windows 7 is exactly like Vista - i.e. incompatible with perfectly working equipment - for several PCI add-on cards and my trusted 1212u scanner. My solution: I'm ditching Windows 7 and going for Ubuntu. It supports the 1212u fine with the SANE package. It's ridiculously wasteful to toss working peripherals just because Microsoft can't be bothered to offer decent support for its paid software.
Mar 05, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Copies made with or without ADF come out with multiple black streaks
Sounds like you scanner is dead. Not much you can do. New all in one machines use very low quality parts to lure people with the features and then **** out in a year or so to make you buy a new one. HP scanners a somewhat more reliable but can be prone to the same problems.
Jan 18, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Kodak i260 scanner wont work on vista
This is a non Vista compatable product.
It may run on Windows Vista 32bit Business though.
May 05, 2008 | Kodak i260 Duplex Color Scanner
Scanner problems
try to change cableof scanner to pc.
Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One InkJet Printer Logo
240 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
