Question about Acer Aspire 5100 Notebook
Acer aspire 5100 black screen
I replaced my motherboard and LCD inverter but still not working.after switching it off on the power up button a few times it came on and booted up.I unpluged the power cord and moved the laptop to the table .The screen went blue with stripes so i switched it off again,now back to same problem ,switches on but screen still black.the power led and media led comes on then after 3sec the media led switches off and thats it.External monitor dont work either when connected
Regards
Adriann577
  • 5 more comments
  • adriann577 Mar 10, 2009
    Hi Zohail
    Thank you for your reply with your suggestions,I have ordered a new RAM .I will let you know once i fitted and tried it.Hopefully tomorrow.
    Regards
    Adriaan
  • Anonymous Mar 10, 2009
    screen went black during use.
  • adriann577 Mar 12, 2009
    Hi Zohail
    I replaced the RAM but still no luck The only thing I have not changed is the screen and Hard Drive.Any more suggestions??
  • Anonymous Mar 12, 2009
    Hi
    My old ram was a 1GB and i got a 2GB .It was in the 2nd slot from the top(one beneath).Just the one RAM.I got it from Mr Memory and their specs say the 2GB i got will work on my acer aspire 5100
    If i take the HARD DRIVE out and switch it on the power light comes on and stays on.The D2 led (media light) with the little book symbol does not come "on"Then when i put the HDD back in the d2 led stays "on" all the time.The screen stays black all the time.Now when i turn the power off and back on the D2 led only comes on for 3 seconds again
    Regards
    Adriaan
    Posted by Guest on Mar 12, 2009
    Hi
    Regards
    Adriaan
    Regards
    Adriaan
  • adriann577 Mar 13, 2009
    Hi Zohail
    I did try both slots but to no avail.I will send it to a service center
    Thanks for your patients and effort in trying to resolve my PC problem.
    Regards
    Adriaan
  • shahid978 Apr 06, 2009
    hi,
    i was installing bios updated version the laptop got hanged and i restarted it of power button but wasnt working so i took of its battery and restarted, but just black screen is coming up , no any activity showing. please help
    President:
  • 1,223 Answers
Pls check the RAM i think it is a RAM malfunction it has nothing to do with lcd if ur system does not bootup and u dont see any hard disk activity as loading OS files while the screen is OFF black then try changing RAM , or if u have 2 chips of RAM try one at a time in one slot that is the upper most or get another one to try with same specs
aslo try connecting the monitor out this will trouble shoot ur LCD screen and vga
pls let me know if i can help more , and rate me FIXYA if i fixed
Posted on Mar 09, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais Mar 12, 2009
    ok try one thing take out the hard disk connector and see if it turns on and it goes to bios to trouble shoot the hard drive
    and RAM have u totally changed the chip with another one and installed the chip in upper most slot or the one beneath may be there is more in this to look out , pls look at the specs of the RAM are they same as ur old one
    pls tell me the results
  • Shoaib Rais
    Shoaib Rais Mar 13, 2009
    pls try in both slots kindly and check the specs of RAM shud match ur original RAM chips u have to go to service centre i think it is more complicated stuff and remotely i think it cant be resolved
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    KINDLY ENCOURAGE US TO HELP OTHERS !
    I was trying to help and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
    Regards
    Zohail
White screen but plugin monitor works. is it the screen?
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5100/Aspire5100sp2.shtml
http://www.laptopscreen.com/English/model/Acer/ASPIRE~5100/
So you PHYSICALLY checked the connection of the Video Cable, TO the motherboard, TO the screen Inverter, and TO the back of the LCD screen?
Visual inspection will NOT do. If either motherboard connector, or LCD screen connector is loose, the width of this letter -> I < you won't see it, and it will affect the video signal.
The Video Cable connects to the motherboard under the Middle Cover, above the F4 and F5 key on the Keyboard. (Left edge of F4 key over to middle of F5 key)
[Middle Cover is Acer speak for Switch Cover. The cover strip above the Keyboard, and below the LCD screen ]
aspire-3100-5100-5600-lcd-cable-dc020007o00-.html
http://www.laptops-we-r.com/prestashop/aspire-5100-parts/109-acer-
Click on the view to enlarge. Top left side connects to the LCD screen. Rectangular Black connector with thick round cable, at the bottom, connects to the motherboard. Small cable coming off at the bottom, connects to the screen Inverter ]
From the motherboard connector the Video Cable routes up under the left Hinge, and into the Display Assembly. It then connects to the screen Inverter, and LCD screen.
From normal opening, and closing of the laptop, repeatedly, the Video Cable may become pinched.
This can lead to loose connections.
It can also lead to damage of the Video Cable.
If the sheath of the cable shows apparent signs of damage, the tiny wires inside may be damaged also.
Stretched/Broken
This means to ENSURE that the Video Cable is NOT the problem, a continuity test needs to be performed on all of the Video Cable's wires. (OHMS)
If an economical multimeter ($5 to $12) is not available, suggestion is to take it down to the nearest 'Mom and Pop' computer store, and have them check it. Labor charge should only be a few bucks.
Video Cable checks out it's on to the screen Inverter, for the diagnoses.
[NOTE*
This diagnoses is for an Acer Aspire 5100 Notebook PC. Uses a single (1) CCFL for a Backlight, and has a screen Inverter. Laptops that use LED's for a Backlight generally do not use a screen Inverter]
Did you test the screen Inverter, or replace it?
http://www.amazon.com/Acer-Aspire-5100-Inverter-PK070005U00/dp/B005F1N5O2
http://www.fonerbooks.com/test.htm
NOTE*
Takes a sensitive multimeter. Read fairly expensive.
Primer;
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor. Suggest start out with your audio turned down ]
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5100 Notebook PC uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
If the screen Inverter is good, the LCD screen is bad.
Replace.
[The LCD screen, and the screen Inverter are a MATCHED unit.
When purchasing make sure you get the correct screen Inverter, or LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 09, 2012 | Acer Aspire 5100 Notebook
Acer red light battery
1) http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Yes, I know. Aspire 5100 series of Notebook PC, not the Aspire 5230 series. I am looking at the Service Manual for the Aspire 5230 series right now, and the above link is a good basic pictorial guide.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the subheading - Aspire 1200. (1200 in Blue)
Go down to the 6th line, scroll across, and left-click on 5230 in blue.
(Takes few seconds before the first page comes up.
In the PDF file page number box at the top, go to Page 119)
2) If you mess up with the connection of the LCD Panel Cable, to the LCD Panel, (On back), your laptop will not power up.
Those tiny contact pins on that cable's connector, must line up exactly, and be plugged in tightly to the LCD Panel.
Not plugged in tightly? You won't see it visually. You have to physically check.
Also use the old tape that was there, to tape over the connector once installed, on the back of the LCD Panel.
Ripped it all the way off? Oops! Use some new tape. (Not duct tape, scotch tape, or medical tape. Box tape with strands in it)
3) Connector of LCD Panel Cable, connected tightly into motherboard?
4) Screen Inverter wires connected? Connectors are keyed differently from each other, BUT, are they connected correctly?
5) Why was the LCD Panel replaced? Damaged? Did the LCD Panel Cable receive damage? Did you perform a cursory visual inspection of it's sheath, at least? Sheath showed ANY damage, did you perform a continuity check of each wire in the cable, with a multimeter set to Ohm's? (LCD Panel Cable unplugged from motherboard, and LCD Panel, of course)
6) If there was damage, did the screen Inverter receive damage?
7) Connect the LCD Panel Cable's ground wire/s back to THE ground screw/s? Good bright clean connection area for those eyelet ground terminal/s?
8) Did you crossover the new LCD Panel to the old LCD Panel, to make sure it is a direct replacement?
NOTE*
A screen Inverter, and an LCD screen, (LCD Panel for Acer), are a MATCHED unit.
9) AC adapter plugged into power, and plugged into laptop, along with the battery?
Post back in a Comment, and if none of the above is the problem, we'll go on from there.
Regards,
joecoolvette
Jun 07, 2012 | Computers & Internet
My acer aspire bl51 doesnt open up at all, the power turns on , but there is a black screen what can I do to remedy this?
Hi liquidblue7,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
My screen on my toshiba laptop screen is going in and out do I need to buy a new scren/
Most likely your issue is caused by a failing LCD Inverter. You will need to have this replaced. Part is available here: http://cgi.ebay.com/Acer-Aspire-One-A110-A150-LCD-Screen-Inverter-B089AW01_W0QQitemZ190363835846QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2c52919dc6
This site explains the process for an Aspire 5100 which can also can be used as a reference for your Aspire One model http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 14, 2010 | Acer Aspire One PC Notebook
Acer aspire 3100 screen is black but it works fine through vga.
at the bottom of the laptop screen behind the plastic is a inverter that can fail look one up on ebay ...
20 bucks to fix
New LCD inverter Acer Aspire 2000 3100 5100 5110 5720
Sep 03, 2009 | Acer Aspire 3100-1405 Notebook
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
Screen
Try hitting the Function key and then whichever key on your keyboard swaps monitors. On mine, it is Function + F8. Also try hitting the little switch a few times that gets pressed when you close the lid.
Dec 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
413 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
