Question about Canon CanoScan 3200F Flatbed Scanner
Lines on scanned documents
When using my CanoScan 3200F flatbed scanner, I get vertical lines across the page obliterating the scanned image.
    President:
  • 1,223 Answers
Pls update the driver
http://canon.driversdown.com/Canon-driver-list/s_421_1.shtml
pls clean the scan glass , if it helps otherwise
ur CCD engine inside the scanner is weak now after use there is no point in getting it replaced as it is not worth pls find a new scanner
HP are excellent and MUSTEK are good and economical
pls rate me if i diagnosed ur fault
Posted on Mar 09, 2009
I know this posting is old, so will not help the person who originally asked this question, but recently (January 2015) I have had the same problem of lines showing on scanned images and have been looking for a solution. I tried cleaning the glass (many times) and this made no difference. After reading several blogs recommending technical solutions that went over my head I began to think that I would have to buy a new scanner as mine is now quite old and it would not be worth paying for it to be repaired. However, I have now fixed the problem myself and it was very simple. Hope this works for other people with the same problem. I turned off the computer and pulled the mains lead and the USB lead out of the back of the scanner and left it for a while (like you would with other devices such as freeview box, and internet modems etc, when they are not working properly) - and this worked! Scanner is good as new now. Good luck.
Posted on Feb 28, 2015
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Windows 7 does not detect CanoScan 3200F using its drivers.
Downloading Canoscan Toolbox is required in addition to the driver.
Oct 31, 2009 | Canon CanoScan 3200F Flatbed Scanner
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
I want to download driver cd for CanoScan 3200F.
Go to:
http://software.canon-europe.com/products/0010013.asp
Select your operating system and preffered language for the driver installation and a link will pop up.
Mar 10, 2009 | Canon CanoScan 3200F Flatbed Scanner
CanoScan 3200F
i lost thish scanner cd and now i want its softwere
Nov 24, 2008 | Canon CanoScan 3200F Flatbed Scanner
Power adapter specififications for CANOSCAN N640Pex Color Image Scanner
scanner is on ant then scan documents but dont show image.it show multiply lines.
help me
Apr 08, 2008 | Office Equipment & Supplies
Saving scanned images
I need Canon CanoScan LiDE20 Scanner Driver for Windows XP
Dec 10, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan 3200F Flatbed Scanner Logo
576 people viewed this question
old marine
old marine
