Question about HP Officejet 5610 All-In-One InkJet Printer
I replaced the colour cartridge in my printer but its still not printing properly..tried putting a different cartridge in but same problem...
bluegreenash
  • 661 Answers
SOURCE: Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Posted on Sep 27, 2007
Blue Hammer
  • 167 Answers
SOURCE: HP F380 printer
This happens when your print head gets dirty. Just claening the print head should solve your problem. To do this: Click start button > click Printers and faxes. > Right the printer icon > click properties > Here you should find something like "Head cleaning" or "Clean the print head". This option can be used to clean the priter head automatically. If it does not work, you can manualy take out the cartridge and dip it in to IPA (Isopropyle alcohol) solution would clean the head[dip the head only not the complete cartridge]. After a few minutes (10-20) you can fit the dry cartridge the printer. If nothing works try changing the cartridges. Note: When the ink is running out this may occur. The only thing we can do is to replace the cartridge.
Posted on Oct 06, 2007
khanmohammad
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
SOURCE: Install cartridge
I did a master reset and now it will print but the ink level for the yellow cartridge still shows "empty" even though it is a new one but at least it prints for now anyway.
Master Reset:
Turn off printer and unplug.
Hold down "OK" button and "Help" button and plug in at the same time.
Turn on printer and wait for reset to finish.
It worked for me. Hope it works for everyone.
Posted on Oct 08, 2008
freetek
  • 5568 Answers
SOURCE: HP PSC 2355 incorrect print cartridges error message
Some later machines can detect aftermarket cartridges and refuse to use them. I don't know why HP does not have the same type numbers available in the UK.
Posted on Oct 07, 2009
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
My printer prints out colours different to monitor - i.e., brown prints out as mauve, green as aqua, and yellow as pink. I have replaced all cartridges (and removed all coverings) with genuine Canon...
Sounds like the wrong colours were installed temporarily. It may never clear properly.
Try printing complete pages of one colour until the correct colour arrives.
Jun 28, 2017 | Canon Refillable Cartridges For Pixma...
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
Colours not printing properly
You need to specifyy what printer you have.
If the jets are part of the cartridge like HP and Lexmark, the clean the contacts on the cartridge and the printer and try again. If no-go, replace the cartridge.
If it has only ink tanks like epson, you need to purge the ink channels that are not working... Magenta and yellow with cleaner and a syringe or sqeeze bulb.
Jan 28, 2010 | Office Equipment & Supplies
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
Not printing at all.
does it print colour ?? have you tried printing a colour document i have experienced with some clients where the b&w wont print but colour will. otherwise it is better almost to just grab a new AIO inkjet
Aug 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Hp psc 1350 colour printing problems
Sir,
Check this link to solve the problem
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 28, 2009 | HP PSC 1350v All-In-One InkJet Printer
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
