Question about Microsoft Windows XP Home Edition
How to club two colums text into income colum & how to **** one colum text to different columns
  • s2fast_2furi May 11, 2010
    be more specific please!
  • Kuldeep Kumar Dubey
    Kuldeep Kumar Dubey May 11, 2010
    Are you referring to MS Excel for above problem?
    Please complete your question. Because if so, its very simple.
  • 36 Answers
Whatever the software might be.. excel or word.. just select the columns.. right click.. do whatever you want.. you'll do the needful if you can read and understand english.. its very siiiiiiiimmmmppppllle..
Posted on Mar 20, 2009
Need to remove steering column on a 1992 lincoln town car
Remove the steering wheel, turn signal reset (plastic), remove clip and spring. Remove trim to expose the entire colum. Disconnect all connectors. There are four main bolts holding the colum up. Remove the bolts and lower the colum. At the end of the steering shaft there is a bolt going through the colum. Remove the bolt. The colum can then be removed.
Mar 04, 2011 | 1992 Lincoln Town Car
On the column shift lever does not accuate transmission shift when moved.
its probably a gigantic piece of ****, just like my f350, ford used a cable style shifter and a retarted lever system in the steering colum. when i opened my colum, i found about 3 lbs of aluminum dust from what used to be the shifter lever inside the colum housing the slop in the lever caused the shift cable to travel too far and snapped it so i replaced it just to have the cable snap again. i guess im going to have to change the entire colum.
Nov 27, 2010 | 1996 Ford F350 Crew Cab
On my org. steering colum the blue wire that runs frome the shaft of the colum onto the white sircet panel. so i replaced the whole colum and now starting disable. 98 deville. what should i do?
If you are using the key and switch that was in replacement column, the resistance of the key pellet for your car is wrong. Provided you connected everything up then the easiest way would be to take your old key (out of old part) and the key from your replacement column to a Cadillac dealer. They can read the resistance of your old key and cut you a new key with the proper resistor. That should start your car.
Sep 03, 2010 | 1998 Cadillac DeVille
How do you change a 1986 chevy celebrity steering column?
  1. take off bottom dash cover
  2. bottom of colum has a bolt and nut that has to come off
  3. then theres 4 bolts holding colum up remove bolts colum will drop
  4. unplug electricalal conection
  5. pull colum out
Feb 09, 2010 | 1986 Chevrolet Celebrity
Steering column loose and causes auto to stall and jump out of gear when steering wheel moves.
There are 3 tilt colum screws deep inside the colum, it's common for them to come loose and eventually cause wiring problems. special tools are required to thighten the torx head screws.
Used colums for that year are cheap however.
Jan 29, 2010 | 1986 Chevrolet S-10 Blazer
Sum of the greatest run of negitive numbers
Hi, Not sure if this is what you have tried:
1: Assuming each run is on a different column
Run1 Run2 Run3 Run4, etc...and the maxium lenght of each column is 9 values, but each colum has a different lenght of numbers..
Then you can use:
=MAX(COUNTIF(A2:A10,"<>0"),COUNTIF(B2:B10,"<>0"), {keep adding countif for each colum).
If all runs are on the same colum, then using Pivot tables is easier. If you have a copy of your data, please post it so that I can give you the exact formula ;)
Oct 21, 2009 | Microsoft Excel for PC
Stirring colum is locked
wiggle sterring column back and forth while turning key. You can also take shifter and wiggle up past park
Aug 27, 2009 | 1998 Pontiac Sunfire
If you want the result of your formula in colum "B" to be appeared in 5 others column, simply put new formula in the other colum with syntax "=CELLID".
put "=B1" (withoud quote) in cell C1, D1, E1, F1 and G1. do the same for the others cell, or just drag your cell to the bottom of page. it will copy your formula automatically.
If that not what you want, please update ypur question with more understandable phrase...thank you
Mar 11, 2009 | Microsoft MS OFFICE 2007 SBE MLK (NA) SW....
Excel Exercise
add the correct formula to count the column and or rows
May 27, 2008 | Microsoft Windows Vista Ultimate Edition
I hope I'm getting you right here. Type the following in column "D" =A1-20 Let me know if this helped.
Sep 06, 2007 | Microsoft Office Standard for PC
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
