Question about Sony Cyber-shot DSC-W55 Digital Camera
Pictures are not loading from Camera to Computer
I have a problem with the pics off the CyberShot not loading into the computer, We just got it back from being totally reloaded with Windows 98 Proffesional, I first was able to reload pictures. Next day or so tryed to put some more on and it wouldn't respond as before, I have a memory stick card reader/writer that I plug the memory stick into and then into computer... It makes the sound as if it's going to upload but then nothing. Any Idea whats a miss on this end?Not able to load Pictures for CraigsList!HELP!
  • randykmay Mar 11, 2009
    I have been using a Memory stick card reader but it will not alow pictures to flow to computer, As it did just befor taking it in to have it fixed. toal re load of Windows 98 er XP
You may need to load drivers for usb devices with windows 98
after a search on google, you should be able to find something here.
Good Luck
Posted on Mar 17, 2009
  • 68 Answers
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Posted on Mar 10, 2009
  • Karan  Naithani
    Karan Naithani Mar 11, 2009
    Heyii Randyk as you said it makes sound as if its going to upload but nothin happens,so considering a problem in your comp,may be your usb port isnt working well or you need to update driver.
    Check if your card works on some other computer too..
How to copy pics to pc?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 21, 2012 | Sony Cybershot DSCW370 Digital Camera
How can I transfer pics from sony cybershot dsc-s950 to computer ?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 22, 2010 | Sony Cybershot DSC-S950 Digital Camera
I am not able to load my pics to the computer...and when I try to view them it says file error on my computer. Sony Cybershot dsc-s930...I really want my pics
Consider NOT connecting your camera to your computer.
Nov 15, 2010 | Sony Cameras
I can view the pics from my camera i.e sony cybershot, as soon as i connect it to computer, it shows nothing. what to do? never experienced such problem, please help.i cant transfer the photos to my...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 11, 2010 | Sony Cybershot DSC-H3 Digital Camera
8x10 inch pictures transfer to Photoshop as 9x12 centimeters
open them in some like window pic manger and change the size there then after that up load them to your photoshop
Jun 01, 2009 | Sony Cybershot DSC-H3 Digital Camera
CANT TRANSFER PICS
Daisyramon, Have you checked the lock tab on your digital card that stors the pictures? You may have inaverdentally pushed the slide lock by accident to the protected side. If you did just push it back to the oposite side of the card. Hope this helps you. I always pull my card from the camera and insert it in the USB port on the front of my computer and open my pictures there and also transfer any to the card from the computer.
Tom
May 15, 2008 | Sony Cybershot S650 Digital Camera
Lost Pics
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card:
http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
May 14, 2008 | Sony Cybershot DSC-T200 Digital Camera
Deleting pictures from cybershot viewer
Emmmeee,
I had the same problem with my digital cam/corder! An alternative solution to deleting pictures off the camera is, trickily enough, through your computer! This may be a bit of a hassle as you have preloaded your pics. What you will need to do is redownload your pics. You should be asked the option of deleting your pictures after download, and you click on the box.
Feb 07, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
120 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
