Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150c shuts down orange flashing light
My computer shuts off on it's own. No warning, the power light will blink orange and the only way to get it to work again is hold the power button for approximately 7 seconds, allow the computer to shut off, then turn it back on again. There is no telling when it will shut off again.
  • 2 more comments
  • MARIA743 Mar 09, 2009
    COMPUTER SHUT DOWN AND ORANGE LIGHT IS FLASHING ON POWER BUTTON. I TRIED HOLDING IN POWER BUTTON, NO LUCK, UNPLUGED POWER CORD AND PLUGED BACK IN, NO LUCK, STILL FLASHING.
  • nacho76 Mar 29, 2009
    I have a 5150C (slim case). It works for a while and then it shuts down.Orange light flashes. I am suspecting the cpu is overheating. I have run the virus scan. Nothing was found. I have replaced the thermal compound between the cpu and the heat sink. That has shown an improvement in durration of the operation between shut downs. The problem presists. I have removed the side cover from the computer to improve exposure to cooler air. It seems that the problem went away for a while untill yesterday. Now the computer is shutting after about fouty five minutes of operation. I am hearing some unusual noises from the inside of the computer. At first I thought it might be a hard drive. After more thourough investigation (having my ear in the close proximity of the hard drive) I have determined that I can rule it out as a suspect. I am narrowing my investigation to the two fans that are built into the system. One of them (or both) may be faulty. I will post my findings.
  • MARIA743 May 11, 2010
    Yes, the power cable is connected properly, no viruses, not under warranty. I ordered a new power supply box. Now, how do I replace the old one with the new one?
  • Jim Scott May 11, 2010
    have you run a virus checker lately ??? could be a virus
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Posted on Apr 06, 2009
  • 55 Answers
Its a case of bad power supply.If the system is still under warranty,please call Dell Technical support and get it replaced
Posted on Mar 16, 2009
  • 271 Answers
First, Check power cable is connected properly or not.
Second, Right click on My Computer...
Click Properties
Click "Advanced" tab
under "System Failure" see if "automatically restart" is checked. Uncheck it if it is. That usually causes the computer to spontaneously restart.
Third, Scan your whole system for viruses.
Thanks
Posted on Mar 09, 2009
2 Suggested Answers
SOURCE: Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Posted on May 12, 2009
I've got yuyun_cantix icon on my desktop. Could you ,please help me with this problem? Thanks.
not a real description of the problem
try this
right click on the icon and in the drop down box--- delete ---
the program will still be on the computer
if however you wish to remove the problem entirely--go control panel-- go programs -highlight yunyun line-- click uninstall and then when finished go to the icon on the desk top and follow the first instruction
Jan 09, 2017 | Icon Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
How can i download falsh player on to 2011 imac desk top threw Linux ubentu browser ?
Ok, there are a number of issues with you spelling so I am going to assume you meant the Ubuntu OS. If that is the case the Flash Player install is done by the following:
If you are using the more modern versions of Ubuntu, simply install the Adobe Flash application from Ubuntu Software Centre.
If you are using a version that does not support the Software Centre, try:
Go to the Adobe website.
  • Click on "Download the Latest Player," and choose ".deb for Ubuntu" from the drop down list.
  • Choose "Save File" from the pop up window.
  • Open a terminal window.
    The terminal window will be found under Applications -> Utilities.
  • Change to the directory where your downloaded file was saved.
    cd Download
  • Install the libcurl3 library: sudo apt-get install libcurl3
  • Install the Flash Player: sudo dpkg --install install_flash_player_<version>_linux.deb
    Replace <version> with the latest version number.
  • Restart Firefox.
  • Check that Flash Player was installed.
  • Jul 08, 2014 | Computers & Internet
    How do I cancel netflix???
    Open Safari, go to netflix.com, sign into your account. On the drop down menu in the upper right, click on "My account". Click on cancel whichever service you no longer want to have.
    Fairly certain you cannot cancel your service from any of the mobile Netflix apps.
    Jun 02, 2014 | Computers & Internet
    Screeen is upside down
    If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
    For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
    I hope this helps.
    Jun 01, 2014 | Computers & Internet
    How do i reset my computer to an earlier date?
    Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
    Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
    Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
    I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
    Jul 27, 2011 | Computers & Internet
    Mouse and keyboard have no power
    If your mouse and keyboard work properly with another computer or laptop the problem could be :
    A) if devices are USB :
    - defective USB port : chose another USB port;
    - USB port inactivated in BIOS : check and activate;
    - motherboard defective : replace motherboard.
    B) if devices are PS/2 :
    - damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
    - motherboard defective : replace it.
    Oct 04, 2009 | Computers & Internet
    I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
    Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
    Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
    Thanks.
    Mar 08, 2009 | Computers & Internet
    Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
    1,178 people viewed this question
    Brian Sullivan
    Brian Sullivan
    joecoolvette
    joecoolvette
