I need a diagram solution for the bios A13
Remove the BIOS battery and the main battery for 20 mins. then replace the batteries and boot up the laptop. If you still cannot get into the BIOS without a password then -
REMOVE BIOS PASSWORD with these programs
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
SOURCE: Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
SOURCE: cpu upgrade latitude d800
what do the Lock Lights indicate (Flashing , ON, ON perchance) it appears that the CPU is either not compatible or bad. Have you tried the original porcessor?
SOURCE: bios password dell d800
Remove BIOS battery. Short BIOS jumper or leave the battery out for a long time(Over night,maybe) This should default the BIOS to having no pass word present. If that doesn't work then evidently Dell has one within the BIOS . Just ask them.
SOURCE: WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
