Question about Garden
I have a Ryobi Lawn Hornet MK2 which belongs to my brother and I offered to try and fix it. Two of three fuel tubes broke and he is uncertain where they go (as am I). There is a primer pump with two tubes attached, two tubes attached to the carby and two go to the fuel tank. One is filtered in the tank, the other not. I suspect the filtered tube from the tank should go to the primer, the outlet tube on the primer to the carby and the second one from the carby go back to the tank. Have no idea which tube on the carby, primer or tank is in/out? Can you help. Machine start with considerable effort but cuts out.
  • 3 more comments
  • leeminers Mar 12, 2009
    Apologies to all. Don't know where I got the MK2 bit. A sticker on the motor says :-
    Eng Family 4031UB 24RA-EM Date Code -601?
  • beakman50 Mar 13, 2009
    have the same problem with 3 fuel lines on the grass scorpion.dont know what goes where.looking for a pdf manual fir it but no luck
  • leeminers Apr 05, 2009
    Sorry if comment posted Apr 05 2009, re "shooting the messenger" relates to myself. Most certainly now, I have all the info required to at least get the lines connected to the right ports. Many thanks to all those having input.
  • Anonymous Apr 08, 2009
    I can't get the bulb to take gas. Keeps getting air that appears to be coming from the top of the carb.
  • John McKinney May 11, 2010
    If you can get me all of the numbers (model, serial, type, etc.) off of the engine, I can walk you through this or get you a diagram to help you. Hope I can help.
    Problem Solver:
  • 6 Answers
IVe worked out that the tube from the filtered tube ( the lowest part of the tank) goes to the bottom entryof the carb and the other goes to the primer bulb. the other side of the primer bulb goes to the top entry of the carb.So the barb has two entry points,the top being to prime for start and the bottom for ordinary running.I found this works for me.
Posted on Mar 24, 2009
What is the fuel mix for a Ryobi lawn Hornet Mk 111
Buy a 2-cycle oil of your choice and mix it according to what the oil says to mix it.
You'll be OK.
Sep 16, 2017 | Ryobi Garden
Ryobi Lawn Hornet rlh1100a mk111. Having purchased two new fuel lines how do I pull them through fuel tank without exerting too much pressure and possibly breaking new tubes. There is obviously a trick but...
Take a small stiff wire, put it through the fuel line hole and filler neck of tank. Cut the end of the fuel line on approx. a 45 degree angle to make it easier to start it through. Wrap the wire tightly around the end of the fuel line about 3 or 4 times do not wrap around the wire itself, that makes it harder to start in and pull it through slowly helping it along by pushing on it, do this from outside the tank, and when it is started in it is easy to pull through. I hope this helps you out, best regards.
Dec 20, 2010 | Ryobi Garden
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel ratio for Ryobi lawn hornet mk 2
25 to 1 = 200ml of 2st oil to 5 lt ulp
OR I use 150 ml "stihl" 2st oil to 5 litre of ulp Less smoke and better oil.
Jan 12, 2009 | Garden
Can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi lawn hornet mk2
Change your spark plug
If the fuel oil mixture is too oily it will foul the spark plug and no cleaning will get it right.
If there is a lot of oil in the crankcase it may foul the new spark plug so another new one is needed
Aug 10, 2008 | Electrical Supplies
Garden Logo
1,400 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
