Question about Averatec 3200 Notebook
My computer has a device but no audio.what am I going to do?
It started When Irefformat my computer...Ithink the problem is that I have no installer of the motherboard,..what am I going to do?
    Genius:
  • 2,785 Answers
Plz check the manufacture website for the drivers
Posted on Mar 09, 2009
It asking for modem device on high definition audio bus driver and sound is not coming...
  • 1
    Click the link "hp: Modem Driver Installer for Microsoft Windows XP (32-bit)" listed in Resources if you run the Windows XP operating system on an HP computer; for Windows installed on a Toshiba computer, go to Step 3. For all other types of computers running Windows, go to Step 4.
  • 2
    Click "Download" from the HP website and click "Run" to install the high-definition audio (HDA) modem driver package. If the modem device does not work properly after the driver has been installed on your Windows XP computer, go to Step 9.
  • 3
    Click the link "Toshiba Audio Drivers" if you run Windows and use a Toshiba computer. Find your operating system, click the appropriate driver listed and then read the installation instructions on the screen to download the driver. If the modem device does not work properly after the driver has been installed, go to Step 9.
  • 4
    Click the "Start" button and click "Control Panel."
  • 5
    Click "System and Security" and click "Device Manager" under "System."
  • 6
    Click "System Devices" and right-click the "Microsoft UAA Bus Driver for High Definition Audio" device.
  • 7
    Click "Update Driver."
  • 8
    Update the "PCI" description drivers (PCI bus and PCI device) and any modem device that displays an exclamation point to the left of it. If the modem device does not work properly after the driver has been updated, go to the next step.
  • 9
    Visit the computer hardware or operating system manufacturer's website for further support
  • Jun 13, 2011 | Computers & Internet
    After formatting my compaq laptop with windows xp my sound card did'nt work.ithink its gone out..how to buy new card?and how much it will cost
    dont think about buying a new soundcard until you have tried all possibities to fix the sound
    if your computer came with a motherboard disc the sound drivers could be on it
    you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
    a yellow? question mark means you need to install/update driver to do this
    right click to install driver also
    click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
    click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
    (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
    also
    click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
    if his does not fix the problem
    have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
    the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
    try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
    hope this helps
    don
    Feb 22, 2011 | Compaq Audio card Sound Card
    My computer has audio problems. when i check, the audio controller is not installed. pls, where can i get an audio controller for my amd sempron 2400+?
    Hello
    1. Go to "Start > Search" and type in "devmgmt.msc." Hit "Enter" to start the search process. The Device Manager will pop up on the screen. This feature shows you which devices on your computer are not working correctly.
    2. Right-click on the audio controller files that have a question mark or exclamation point next to them and select "Uninstall." Save the changes and close the menu.
    3. Go to "Start then Restart Computer" for the changes to take effect.
    4. Go to "Start > Search" and type in "devmgmt.msc." Hit "Enter" to start the search process. The Device Manager will pop up on the screen again.
    5.Hit "Scan for Hardware Changes" on the Device Manager menu. Let it scan "C:" drive. It will let you know if it finds any new devices or drivers to download.
    6. Go to the website of your audio device and download the appropriate driver to your computer. Double-click on the file to open it and follow the instructions on the screen to install it to your computer.
    7. Restart your computer for the changes to take effect.
    8. Open the Device Manager again to see if the exclamation points next to the audio devices are gone.
    THANK YOU FOR VISITING FIXYA
    Jan 29, 2011 | AMD (90613) PC Desktop
    I can't play windows media player and can't listen any sound.
    What about the audio drivers, at the device manager is everything about the audio in OK condition?
    Stelios.
    Feb 20, 2010 | Mercury PVCLE266 Motherboard
    My problem is about audio sounds
    Here is a solution : On desktop go to ::
    my computer----mouse right click----properties----system----device management. There you can find symbols for all devices that are already installed on your system . Scroll down until you find the definition of your audio device software , for example , if your audio driver software is a realtek then right mouse click on it , then you'll find disable , just disable it and then uninstall the audio driver software ! After that you should restart your system . When system started again , install the software again , and restart the system once again . Now you should hear the operating system starting tone .. If you didn't hear the tone , then go to device management again and enable the audio device once again .
    good luck . rate if useful please
    Jan 27, 2010 | Audio Players & Recorders
    When speakers are on there is no sound
    Here is a suggestion : On desktop go to ::
    good luck . rate if useful please !
    Jan 22, 2010 | Dell 5650 Computer Speakers
    I have my notebook intel atom n270,im having a problem w/ my sounds and audio device coz its not working,.
    Before it would not did you going to put the software driver provided (Utility Disc).
    See to it that it is install already and also check the BIOS if this two devices are disabled or not installed yet.
    Nov 07, 2009 | Office Equipment & Supplies
    No audio devices installed
    Do you have windows XP or Vista?
    Do you have sigmatell audio card?
    When this happens go to start->run type in services.msc and press run.
    Find Windows audio service. Right click and select properties. SElect start type "automatic" and click on start.
    Audio should work.
    Please leave your feedback if issue was solved or if you still have that problem
    May 28, 2009 | HP Pavilion DV6500T PC Notebook
    Audio is not working for P5SD2-VM motherboard...
    You probably need Microsoft UAA drivers first
    1) Remove any installed audio drivers through device manager
    2) Download Microsoft UAA drivers for your O/S
    3) Install them and reboot
    4) go to device manager right click sound and update driver
    It will go on the net and in most cases find and install them
    Nov 28, 2008 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
    Volume software
    Dear Jacque visit manufacturers site. download audio driver. istall it ithink this will solve ur problem.
    Feb 25, 2008 | HP Compaq Presario V2000 Notebook
    Averatec 3200 Notebook Logo
    Top Averatec Computers & Internet Experts
    k24674
    Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
