2004 Ford F150 Logo
Posted on Apr 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2004 ford f150 5.4 triton when I take off from park it sometimes stalls and it sometimes has a surging no power, it also has the no power surging takeing off from a stop sign or light at times. This could happens two days in a row and not happen for two weeks again, I've took it in and no codes come up and it never seems to do it when the garage has it, any ideas ?
mark
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 46 Answers
  • Posted on Apr 12, 2013
mark
Expert
Level 2:
New Friend:
Night Owl:
Answers
46
Questions
Helped
11472
Points
112
Maybe a fuel starvation check fuel filter
also check your transmission oil level
and check cable connections to gearbox are on properly and not bad connection hope this helps
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Aug 16, 2008
SOURCE: engine stalls at stop lights and stop signs
sounds like the torque converter lock up might not be disengaging. You might also want to check for engine vacuum leaks. Does engine idle smoothly when in park or nuetral ? if the idle is good I would suspect torque converter problem.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jan 10, 2009
SOURCE: My car surges some times
Follow this procedure for these kinds of problems.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Anonymous
  • 659 Answers
  • Posted on Jan 29, 2009
SOURCE: my 2004 Ford Escape stalls
these vehicles have a problem with the torque converters locking up after a long drive. this will cause it to stall when coming to a stop. Do you feel a shuddering when stopping?
Anonymous
  • 106 Answers
  • Posted on Apr 02, 2009
SOURCE: Engine Stalling '65 Mustang
replace the accalerator pump in the carbrator this is located at the bottom of carb. or front above fuel filter! this should cure the hiccups and problem.
Anonymous
  • Posted on Apr 15, 2009
SOURCE: car stalls at traffic lights and stop signs
it could also be the idle control valve not working properly, it could be carboned up, remove and clean with a cloth then replace and try car
Need a diagram for power train control module pin identification
http://www.reliable-store.com/products/2004-2008-ford-f-150-cold-air-intake-k-n-ford-cold-air-intake-57-2556
2004 chevy malibu classic idle surges at park and get worse at drive
usually cleaning the idle speed contrlol valve from carbon buildup, fixes idle surge and stalling. try soaking vave in throttle body cleaner or inyector cleaner.
2helpful
I have a 2004 F150 with the 5.4 triton. The other day while driving on the highway with no warning it lost power and quit running. We have gone through the fuel system and have good fuel, other than...
Check if all your ignition coils are firing!! Typical issues are: Sputter/****/misfire under load (foot on gas pedal), stalls, no spark. On these 5.4L, moist and other fluids tend to short the coil out. This is caused by poor design of the coil boots.
Truck stalled out while driving will not start
Not sure about your truck older Fords have 2 fuel pumps 1 in the tank & 1 under cab drivers side. Anytime you change a pump you must change your filter. also check your fuel line if it has been pinched or has a leak pressure will drop
1helpful
My Ford F150 XLT Triton driver's side power window
window regulator failure. Check window regulator guide for damage. If damage replace!! Hopefully this helps
2answers
Engine surges then stalls after a re=start
could be both sensors, Most likely start with the iac motor. Then replace the fuel filters.
Could be the fuel pump starting to go.
Surge and Stall
Check the TPS switch and make sure there is no broken vacuum line also check for Codes.
1helpful
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
