Question about Compaq Computers & Internet
Anyone can give me a circiut diagram for my power supply compaq model no.ps-7231-6cf
    Genius:
  • 1,061 Answers
REPLACEMENTS ARE HERE..http://www.calhountech.com/search/index.php?part=PS-7231-6CF...OR TRY CONTACTING COMPAQ SUPPORT AT....http://h18000.www1.hp.com/cpq-country/cpq_support.html.RICHARDM69
Posted on Mar 10, 2009
Flashing red on light then goes to blue ,but does not come on
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 15, 2014 | LG 37LP1D 37 in. LCD Television
Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
Nov 16, 2013 | HP Compaq dc7600 Small Form Factor PC...
Had a power surge on this tv model klv32s400a, no standby led completly dead. Have opened and checked the power supply as far as I can, supply is present on primary side of transformer but not getting to...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 10, 2017 | Sony KLV32S400A 32 in. LCD TV
Kenwood PS series DC power supply - maximum voltage issue
First thing to do is check the unit with an external meter to see if the internal ones are accurate.
Mar 17, 2017 | Kenwood Computers & Internet
I have a smps(model compaq PS-5500-1C). How can check its out put volatage?
Hello Anvar, hi, to run the power supply on its own, you need to short the green wire with the black wire. (plug in the unit)
using a Volt meter, select a range of DC 50V. put the black probe of the voltmeter to any black wire, and the red probe to the ff:
red is 5V
Yellow is 12V
orange is around 3.3V
Blue is negative 12 (switch or interchange the probe to properly read 12V on the voltmeter)
White is negative 5.
Visit this site for more information:
http://en.wikipedia.org/wiki/Power_supply_unit_(computer)
Apr 26, 2010 | Compaq PS-5500-1C (244163001) 50-Watt...
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
SMPS for compaq proliant 1600 server
my email techdcs@yahoo.co.in I can provide a replacement for the same power supply , it's a brand new one
Apr 26, 2008 | Compaq mATX ATX12V 300w Power Supply Part...
Testing of compaq server psu
please provide more information... are you missing 5/12 volt supply or what? cheers
Feb 07, 2008 | Compaq (480082-001)...
Computers & Internet Logo
216 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
