Question about EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
Compatible memory for P4M266A-8233
I want to upgrade the memory but I don't know the compatibility of P4M266A-8233, can I use PC 400 up to 1gig memory? Pls. help me
It also supports DDR 333 or PC2700 if you change the SDRAM CAS LATENCY configuration at the Bios from 2 to 2,5.
The FSB Frequency and the DRam Frequency is 133 Mhz, wich is multiplied for the default sdram cas latency (2), then you have to use DDR 266.
But if you change this settings of the Sdram cas latency from 2 to 2,5, then the Dram frequency of 133 mhz is multiplied for 2,5 and the result is 333 mhz supported for the mother board.
Posted on Mar 31, 2009
    President:
  • 1,073 Answers
Hi!
No you can not!
This is what memosticks that mobo of yours supports
DDR 200/266
PC100/133 SDRAM
Max. Memory 4.0GB
Good luck
Nic
Posted on Mar 09, 2009
WHAT MEMORY COMPATIBLE?
DDR PC2700 or PC 3200 RAM is compatible.
Up to 1 GB per slot.
Here is a link to Crucial for RAM that is compatible:
Computer memory upgrades for ASUS P4PE Motherboard from Crucial com
Sep 14, 2011 | ASUS P4PE-X Motherboard
Hi I want to upgrade my z3731 Ram but don't know
Dear craig_hep935,
Please visit this Link their you will get a video link on left middle side of the page demonstrating how you can upgrade your aspire z3731.
http://www.crucial.com/upgrade/compatible-memory-for/Acer/Aspire+Z3731/list.html
hope this will solved your confusion
Enjoy
Jun 17, 2011 | Computers & Internet
I tried to upgrade the memory of my 450 sx4 pc from 512mb to 1 GB
You may have installed a memory card or stick (unit) that is not compatible with your computer. Make sure the unit is compatible, as you cannot add just any brand of memory upgrade units to any computer. They have to be compatible.
I suggest visiting the store of where it was purchased or a computer store, or possibly the manufacturer of the computer to find out what memory units are compatible.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | Gateway 450SX4 Notebook
Upgrading memory
pc 800-45 is also compatible. you can get that one.
Dec 18, 2008 | ASUS P4T-M Motherboard
I want to upgrade my graphic card
That video card won't work on your system board. The video card requires a PCI-E expansion slot, but the system board has an AGP slot. You'll need to look for an AGP video card. I tried looking on the site you gave for the card you were considering and they don't seem to have any AGP type cards, so you will need to shop around some more.
Nov 19, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Memory bank 2 is dead, no visual from graphics card
1st -- assuming you did goto youre bios first and adjust where nessicary -- grafics set to AGP not PCI or Pallet snoop (off).
Memory banks running NON ECC ( most common ) ..
blaa blaa blaa -- read ur Bios Update notes -- memory compatability .. and or .. make sure it's seated firmly in its spot-or swap em see if it's the bank or the mem ... run memtest to confirm ..
all else fails or dont want to mess with settings ---
then simply
RE-FLASH with Older Bios ---- see if problem persists ! ..
Jun 18, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
P4M266a-8235
eventhough i am a newbie in this forum, I have already experienced the same problem a while ago in my pc..
The solution is that you have to check that the two memory stick that you have connected is compatible to each other. That is in terms of brand and I see that the 400 MHz (im not sure) is the same so it should work. The one thing that you have to check is the compatibility issue of the two brand.
If they have the same brand, I guess you also have to check if your motherboard support that memory size.
Hope to solve the problem youre having
Dec 10, 2007 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard Logo
319 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
