Question about Irons
Steam pipe and wiring into iron - does negative go to left or right looking from back of iron - your help would be greatly appreciated
  • 400 Answers
The neutral wire would go left and the live to the right. But in all truth it would work either way because in AC voltage there is no negative or positive. They change which is why it is called Alternating current. hope this helps
Posted on Mar 09, 2009
This is a used iron. I filled the water well with bottled water and turned it on to steam. the iron dripped and **** and ruined my fabric with is spot cleanable only. I tried to adjust the steam setting...
Sounds like there are 2 issues, the water is not being heated and the water system has calcium build-up. Get a product called "Lime-Away" most Home Depot's carry it. Fill the tank with it and let is sit overnight. Then drain and fill and flush with clean water a few times. Then disassemble the iron most likely one or more of the contact has a loose wire or ends are burned and carboned up. Clean all contact and replace any burned ends, etc.
Mar 12, 2015 | Irons
Pump wont run
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    My husband threw away the opereating instructions for our iron.
    SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
    Nov 23, 2008 | Euro-Pro Shark GI490 Iron
    Hinari steam vapor iron Model HIN001
    More complete answer...
    If you are having steam problems then the cartridge needs changing.
    I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
    Send Cheque for £5.99 for each cartridge with note of model etc.
    Pulse Home Products Ltd.
    Middleton Road
    Royton
    Oldham
    OL2 5LN
    Aug 24, 2008 | Rowenta Surfline Iron DE-333 Iron
    Black & Decker Iron - Steam Advantage - won't turn on
    Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
    Hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE;
    Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
    Won't steam
    The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
    The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
    Nov 02, 2007 | Toastmaster 3302 Iron
    Irons Logo
    50 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
