Question about Sony Computers & Internet
May need drivers installed??? sony dru510a dvd burner
I recently got a sony dvd 510a dvd burner and put it in a hp puter, went to burn a dvd and wont do anything, no burn, nothing, says cannot write lead in, i need to find out where i can get the sonic thats supposed to come with hp, i checked hp site and couldnt find it, also i talked to a friend of mine and he said u need to install the drivers, i found them at the hp site and downloaded them, however im not sure how to install them, its a zip file and extracts the files to .exe i try to install the drivers (device manager) and tried to click on the exe files and all it does it pop up dos for a few seconds, i was told they are dos drivers anyway, so i need to know if the drivers are installed, how can i check? device manager??? when the dos came up did it install the drivers?
Sony states that all drivers for this problem are done on the OS side. The device should be "plug and play" compatible therefore they dont have any drivers for it. They refered me to Microsoft. (not holding my breath)
Posted on Dec 30, 2009
When you download drivers normally you have a choice of a self install exe or a manual install file.if a self install file isnt avaliable unzip them to a empty new folder then go to the device manager and update from there having it look in the folder you unzipped to.
i would go to sonys site for the driver because they will have the most up to date
Posted on Mar 19, 2009
Sony DRU510A DVD Writer - I can burn CD's, I can watch DVD's, but when I try to burn a DVD it won't recognise the blank DVD. I am using DVD-RW. I use RecordNow DX. I am a novice user. Thanks very much.
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 03, 2011 | Sony DRU 510A DVD±RW Burner
Sony CD / DVD DRU-510A. Reads CD's and DVD's, burns CD's, but will not recognize blank DVD's. Sony support page states: 4X DVD-RW Media Compatibility Notice Please Note: 4X DVD-RW media is not...
Well a quick check here says it should manage 4 x DVD write speeds:-
http://reviews.cnet.com/dvd-drives/sony-dru-510a/4507-3212_7-21226932.html
The only thing I can think of is that lens may have some dust on it, try a CD lens cleaning disk or a blast of air from an aerosol spray can.
After this, I'm afraid its down a replacement.
Mar 17, 2011 | Sony DRU 510A DVD±RW Burner
Can the dual layered discs be burned on the device
The Sony DRU 510A is not a dual-layer burner.
Jan 31, 2011 | Sony DRU 510A DVD±RW Burner
Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
Sony DRU 510 wont burn.
inside circuit belt is loose. show to computer hadware
Jun 18, 2009 | Sony DRU 510A DVD±RW Burner
Sony DRU 510A wont burb discs
if any error come that means your writer is ok only circuit loose
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Can not finalize disk (cd or dvd)
I just burned 6 movies, I noticed that when it goes to finalize, it ejects before finalization is complete. I use FAB Platinum 4.1. I'm going to go into the settings and use Nero burning rom before I remove my Sony and put in my other burner (Plextor) better then Sony I think. I used Nero before and it helped, maybe it will help this time. Why 3 movies did not play, and the others did is beyond me. Dan J
Nov 14, 2007 | Sony DRU 510A DVD±RW Burner
Sony dru-510a , not playing movies
you need powerdvd or windvd which has the decoder for dvd. can it read regular data cd's ? like install a program?
Nov 03, 2007 | Sony DRU 510A DVD±RW Burner
Computers & Internet Logo
309 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
