Question about Acer Aspire 5610-4648 Notebook
Computer ended up with Unlocker, and computer was running slow, reinstalled Windows and getting error(0ax000000e). Research I've found says its an Alcarys worm. Have been unsuccessful in every attempt to remove, please help !
    President:
  • 1,223 Answers
If it was a worm u should have formatted the drive and everything will be ok try formatting ur drive slow format and then install OS
but according to my expertise this error if it comes with blue screen normally (0ax000000e) this is RAM malfunction it is not a WORM my friend kindly change the ram or if u have 2 chips of RAM installed try one chip at a time to see if one is faulty otherwise get another one to test
pls reply and rate me FIXYA if it helps
Posted on Mar 09, 2009
DRAGON NATURALLY SPEAKING, WHEN i CLICK ON ICON I GET ERROR "ACTXPRXY.DLL DID NOT REGISTER ITSELF" CAN I DOWNLOAD THE FILE ?
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it http://youtu.be/rNDBRYdDXqo ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website http://support.nuance.com/compatibility/ . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
May 07, 2014 | Computers & Internet
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
Can u help me get rid of my pc running slow please?? i am losing it
Run Disk Cleanup
When PC is full of junk content or trash files it start performing slowly. To speed up your computer you need to delete all the trash data from your system. You can clean your PC using Windows pre-installed tool Disk Cleanup. To run Disk Cleanup follow the steps below:
  1. Click Start
  2. Type Disk Cleanup in search
  3. Press Enter
  4. Select the drive which you want to scan and click OK
  5. Select files to remove
  6. Click OK then Yes
NOTE: Follow above steps to clean all drives one by one
Run Disk Checkup
System full of errors also affects the speed of computer. You can speed up your slow computer by running Disk Checkup for detecting and removing errors. To do so follow the steps below:
  1. Open My Computer
  2. Right click on drive which you want to check for errors
  3. Click on Properties
  4. Click on Tools tab
  5. Under Error -Checking menu click on Check Now
  6. Select the options and click on Start
Run Disk Defragmenter
Due to huge transfer of data fragmentation occurs in Windows operating system. This also results in slow PC performance. Running disk defragmentation remove fragmentation and allow you to access data quickly. To run it follow the steps given below:
  1. Click on Start button
  2. Type Disk Defragmentation
  3. Press Enter
  4. Select the drive and click on Defragment
  5. Restart your computer after completing the process
Clean System from Virus
Computer infected by any malicious application also runs slow. In this case you have to download and install reliable antivirus program with up to date virus database. Run a complete PC scan and remove all the viruses detected by the program.
Repair Registry Errors
Windows registry keeps on storing information about programs installed on PC in form of keys. Corrupt registry keys cause a computer to run slow. In order to fix this issue and speed up your computer you need to install a System Utilities program which includes Registry Cleaner and PC Optimizer feature. These tools will allow you to boost your computer performance.
To download a reliable and professionals recommended System Utilities program click here.
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Dec 07, 2017 | HEWLETT-PACKARD Black 20" TouchSmart...
My computer won't turn on, it just has a blinking dash on the left hand side I've tried turning it off and on multiple times and nothing will work I have an assigment due at the end of this week...
while the computer is turning on push the escape key and try selecting the harddrive
if it doesn't start to boot into windows then your boot record is probably corrupt you can try fixing it by running chkdsk /r on your OEM reinstall disc that came with the computer, seeing as you have a netbook you will need a external cd rom
Jun 14, 2011 | ASUS Netbook
Hello, i've installed the Dawnspire CD game and when i tried to launch it my computer said, "Launcher.exe - System Error -- The program can't start because MSVCR71.dll is missing from your...
Download MSVCR71.dll from dll-files.com. (It is free.)
Unzip...
Place MSVCR71.dll into C:\Windows\System32
or C:\Windows\SysWOW64 if you using a 64-bit Windows.
Jun 02, 2011 | JoWood Productions Dawnspire (PC) for...
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of...
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Apr 08, 2011 | Systemax SYX Crossfire X58 Gamer Intel...
Computer is very slow I had a bad virus so then replaced hard drive with a new one but pc is still slow
Computer slow downs are possible at all times. The only thing required is that the problem should be found and fixed at the right time.
You can scan your computer for errors here
http://www.keep-pc-clean.com/
May 19, 2010 | ASUS P5GC-MX/1333 Motherboard
Windows xp home addition V2002 SP2 gphone.exe not found
The very first thing we do is to solve your problem about the start-up error. For your information, your operating system was corrupt that is why there is prompt error message appear in the windows start-up. The best thing here to do is to start your computer in safe mode and this can be done by pressing F8 key until a operating system menu will appear. Select Safemode and wait until you get into the User Account Login screen. Enter to your account and then restore your computer to an earlier time. Go to All Programs - Accesories - System Tools - and then select System Restore.
But if this procedure failed, the only last thing should be done is to reinstall your computer operating system. Leave comments for further assistants. okay..
Dec 22, 2009 | Microsoft Windows XP Professional With...
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
