Back to:
Tags:
IBM 14 Bays Netfinity EXP300 Storage Cabinet
Problem in Netware 5.1 with Disk IBM EXP300
By Cornish - usenet poster
I have a Novell 5.1 Netware Server (IBM XSERIES 360). with Support
Pack revision 6, this server is connected with a EXP300 IBM sytem storage
disk. The machines with windows OS get hanged when we open windows
explorer to open a file, even when we try to delete the file that hanged
our machine throught the X- SERVER-Grafical Console, we can??t do it. ?? We
try to restart this server with the command "down", but it doesn??t
work,and then we have to disconnect from electrical net pressing the power
button. When we restart the server all works ok, and this failure
ocurrs .
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Gary10
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Go into monitor - server parameters - NCP, and set client file caching
enabled = OFF and Set level 2 oplocks enabled=Off and reboot the server pls.
Andrew C Taubman
Novell Support Forums Volunteer SysOp
(Sorry, support is not provided via e-mail)
Opinions expressed above are not
necessarily those of Novell Inc.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem in Netware 5.1 with Disk IBM EXP300:
I don't want to Accept this solution
Can you Help with these Drive Cases problems?
Drive Cases
I have a bytecc backupstar me-808 and the drivers will not...
Drive Cases
I need to remove the hard drive from a Maxtor personal...
Drive Cases
I forgot to mention that the old hard drive in the...
Drive Cases
i need to fit seagate hard diive into new enclosure
Drive Cases
the connector to the plug appears damaged, blue light...
Loading problems.
Repair Service
Find Drive Case Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
